Remote Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JPC2061, Dec 9, 2010.
  1. Dec 9, 2010 at 7:54 AM
    JPC2061
    JPC2061 [OP] Well-Known Member
    J.P.
    Maryland
    2010 Black SR5
    Weather tech Floor liners, Flash Light mod, MBRP Exhaust, Grille Guard, Tinted Taillights, Side Steps, Front Windows Tinted to match rear, De badged
  2. Dec 9, 2010 at 9:17 AM
    Frankie_G
    Frankie_G Well-Known Member
    Frankie
    West Seattle, Wa
    idk how much you want to spend but on Amazon they have one for $50 but it's just locks and the start. so i guess it depends on the features you want too
  3. Dec 9, 2010 at 9:43 AM
    gnfreak
    gnfreak Active Member
    keith
    Normal, IL
    we just installed this remote on our 03 Trailblazer and the install guy said he could put the same one into my Tacoma. Diffrent bypass module than the Chevy but required (extra $$). My wife loves it in her SUV. The Tacoma stays outside all the time and i'm thinking i could get use to a warm truck every morning. I was never a big fan of remote starts before. The guy works with me and has installed remotes for years. Total price was $250 installed.
  4. Dec 9, 2010 at 11:31 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Personally I wouldn't get a remote start without two way paging capabilities. This way you know the vehicle starts without having to look at it and you know if it shuts off.
  5. Dec 9, 2010 at 12:07 PM
    Gadvan
    Gadvan Well-Known Member
    cincinnati,ohio
    v6 SR5 TRD
    go with the avital 5303 i got it. 2 way lcd screen pager, works 1500ft away i start it from in bed or in school lol. can show you temp inside truck page you if it goes off and you can add features to it like roll ur windows up and down. im very happy with it. intalled about 500
  6. Dec 9, 2010 at 12:25 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Got a one way ( long Distance ) Compustar starter installed when i bought truck
    Unless you know what your doing , i would pay a reptiable installer to do it.
    I have had it for over a year and half and have not had one problem so far
    and have been impressed by the distance i have gotten it to work
    like from my desk at work inside a large warehouse.
  7. Dec 9, 2010 at 4:19 PM
    MRW
    MRW Well-Known Member
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    Which bypass module transponders do you guys use? PKall? Fortin?
  8. Dec 9, 2010 at 6:30 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I also have remote start with 2 way paging and it was one of the best mods that I have done.
    Mine is from a company called "auto start".
    My only complaint is that in my taco I leave the head lights switched on all the time, when the ignition is off and I open the drivers door they go off.
    The problem is that with the remote start if it ever times out (after 25 mins) of if I shut it off via remote, my headlights will stay on since the drivers door is not opened.
    If I turn off the headlights like I normally would do in any other car, then everything works as normal.
    Sharn
  9. Dec 9, 2010 at 7:30 PM
    Buddha4
    Buddha4 Active Member
    CO
    cold air intake
    Have the same system and very happy with it. The company makes python/viper. If you shop around you should be able to get a better deal than the 500. I didn't need 2 of the 2 way pagers just wanted a basic oger for the backup so I only paid 325.
  10. Dec 9, 2010 at 8:28 PM
    DavidT
    DavidT D
    Pensacola, FL
    Every car I installed alarms on, I used fortin. Very easy to install and doesn't require a spare key.
  11. Dec 9, 2010 at 10:04 PM
    pvas540
    pvas540 Well-Known Member
    Dearborn, Mich.
    2012TRD Sport DCLB 4x4
    Bilstiens 5100 adj with Eibach, Dakar rear leaf pack with 5100's. Wet Oakles. SCS 17" with 275/70/17 Coopers.
    I just installed this unit in my truck via Best Buy. Well they installed and I'm very happy so far. Paid $330 here in Michigan. Once in awhile it takes twice to start. I put it off for several years, but this winter I decided it was time.
  12. Dec 10, 2010 at 5:15 AM
    Gadvan
    cincinnati,ohio
    v6 SR5 TRD
    I got. 2 way lcd remote and regular backup remote with my avital
  13. Dec 10, 2010 at 5:49 AM
    unentered
    unentered Son of Baconator
    Jacob
    Deep Creek, VA
    DCLB4x4MGM
    AMS Filter, WT Mats, Supertop, ScanGauge.
    I plan on using an Autopage 2Way Remote Car Start/Alarm for this, you should check em' out.
  14. Dec 10, 2010 at 6:46 AM
    pinktaco808
    pinktaco808 Hot Steppa
    no matter
  15. Dec 10, 2010 at 6:48 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    best buy near me wanted 400 for a basic one the other day. what a joke, radio place down the road is getting 129
  16. Dec 10, 2010 at 11:03 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    I used a Fortin key-override-all bypass with my Clifford alarm/rs install. The "all" model connects to a couple of wires at the transponder coil reader in the steering column instead at the ECU like the older model bypasses. This is much easier. Also uses one key to program then needs no key to operate once it has been programmed.
    Here is a link to a detailed write up of the entire installation with all the wires and locations I posted to the A/V area of TW once upon a time. Some details will differ depending on the system you install. But the wires and locations should help you out if you try to do this job yourself.
    http://www.tacomaworld.com/forum/audio-video/50202-alarm-starter-dyi.html#post894757
  17. Dec 10, 2010 at 11:14 AM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    Take it back to them and tell them to run a tach wire. If it does not start on the first time, everytime they used a voltage setting. If the wire is run to the tach it will start everytime with no chance of starter grind. They should have done it in the first place, half assed.
  18. Dec 10, 2010 at 11:16 AM
    Daudio
    North Jersey
    '02 SR5
    I get this unit for $95 from one of my distributors, has never failed me once. co-sign on the fortin bypasses too, they work great.
  19. Dec 16, 2010 at 4:17 PM
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    just bought a fortin bypass transponder to accompany my Code 2 way... hopefully it works, any advice from those who have the fortin?
