Remote start.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Captain, Nov 6, 2017.
  1. Nov 7, 2017 at 7:18 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Well even though you have to restart it after you get in, its still warmed up. But to me, for my money, they are more hassle and waste of fuel then they are worth.
  2. Nov 7, 2017 at 9:32 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Just the drone doesn’t work or nothing with the remote start works at all? The Drone you have to pay subscription fees for. If she has separate remotes try them. If it’s not working with them see if it’s flashing the lights giving you an error code. If so it could be a couple of things but usually they just go into valet mode if the battery is low, dies, or is disconnected.
    To exit valet mode try one of these steps:
    With a 4 button remote. Press lock and truck buttons together.
    With a single button remote, turn the ignition on and TAP the button 5 times. Waiting for the LED to flash in between each tap
    Or if you have both remotes you can reprogram the remote and it’ll take the unit out of valet: to do this cycle the ignition key on and off 5 times. The parking lights should flash. Tap the first transmitter, unit should click, then tap the second. Note: it’s best to fill up all the program banks so you don’t have an interference problem. So after programming the second transmitter just repeat the process
    Also you can turn the ignition on and tap the brake pedal 10 times. This doesn’t always work and only works on certain units.
    Hope that helps. If not try to tell me how many times it flashes and I’ll direct you on what the code is
  3. Nov 7, 2017 at 9:42 AM
    AllisFan
    AllisFan Well-Known Member
    On the market as it were
    The regular remote works, she paid the subscription last year about this time (wasn't cheap) and the thing won't work with her phone.
  4. Nov 7, 2017 at 9:57 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Did you call their support? They should be able to ping it and test it. They used to allow the installed to go back in after the install was performed and test functions and stuff but don’t think we can anymore
  5. Nov 7, 2017 at 10:00 AM
    AllisFan
    Her brother started it off his laptop in the diagnostic program. It won't work with the app though.
  6. Nov 7, 2017 at 10:11 AM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    I have a Viper and have on last few vehicles. It's a huge luxury up here @ -40F. Never had an issue. My daughter has a Compustar with no issues. None of us have don't the cell phone start as all I have seen require a subscription. Range is great on the Viper; I've actually started mine while landing at the airport, then walk out and jump in a warm truck!
  7. Nov 7, 2017 at 12:11 PM
    Snakedoctor
    Snakedoctor Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    I see it as a double wear on your starter at that point. I would look into it if you didn't have to restart.
    niko5055 likes this.
  8. Nov 7, 2017 at 3:23 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Not nearly as bad as stop/start tech
    But it does suck. I don’t use mine nearly as much because it does annoy me
  9. Nov 7, 2017 at 3:24 PM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Interested in this as well. No point for me personally to have a remote start with out a take over.
  10. Nov 8, 2017 at 8:43 AM
    17Canadalimited
    17Canadalimited Well-Known Member
    Edmonton AB
    2020 Tacoma TRD Sport Cement Grey
    Just tried this and didn't work on my 2017.
  11. Nov 8, 2017 at 7:23 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There is only takeover on regular key ignition systems. Push button will turn off when you open the door
  12. Nov 9, 2017 at 12:05 PM
    CRIMAR30
    CRIMAR30 2016 TRD SPORT
    MARK
    NORTH CAROLINA
    2016 TRD SPORT ACCESS CAB
    Anyone have the 12voltsolutions remote start with the Smart Start also? If so, does the smart start tell you when the engine shuts off? I also noticed after it shuts off, the doors don't unlock right away, anyone else notice this?
  13. Nov 15, 2017 at 12:37 PM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Not double the wear unless you use the remote every single time you start the truck. So you might need to buy a new starter every ten years or so, if that often?
    whitewolf001 likes this.
  14. Nov 15, 2017 at 2:34 PM
    Larl
    Larl Member
    Chicago-Land
    What is the recommended remote start for us who do not have push button?
  15. Nov 15, 2017 at 3:52 PM
    #35
    whitewolf001
    whitewolf001 Well-Known Member
    TN
    2017 8T0 Tacoma TRD Off-Road
    NZmeek, Skydvrr and Hank Heel like this.
  16. Nov 15, 2017 at 4:27 PM
    #36
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    As I have stated before..... OEM remote starters are being offered as a add-on factory direct on the 2018 Tacoma's. My service advisor said it won't be long before he can order me one for my truck.
  17. Nov 15, 2017 at 4:35 PM
    #37
    whitewolf001
    TN
    As someone whom works in a parts department I can tell you that this isn't likely the case and the advisor is likely just blowing smoke up your chimney. Usually Toyota has accessories rolled out along with the new models when they release and if not, getting them integrated within the second year. The remote start has always been a popular accessory but has absent for the Tacoma in all of its incarnations from the OEM. If it's not rolled out by now, I wouldn't hold my breath but hey, you never know as Toyota Corporate is known to throw us curve balls, like for instance looking on the ASG to see that they added window rain guards for a 2017 model only to remove it within 24 hours. :rolleyes:
  18. Nov 15, 2017 at 5:06 PM
    #38
    RexsTaco
    RexsTaco Well-Known Member
    Vincent
    San Antonio
    Maxtrac spindles Bilstein 5100 adjustable OME 885 coil JBA UCA's Custom leaf pack and Maxtrac extended shocks in the rear. 35x12.5 Atturo Trail blade M/T Moto Metal 18x12 -44 offset wheels.
    Any plug and play kits for an 06 :bananadead::bananadead::boink::boink::boink:
  19. Nov 15, 2017 at 7:03 PM
    #39
    Zandroid
    Zandroid Well-Known Member
    Zander
    SoCal
    '16 TRD-OR DCSB 44
    King Ext Coilovers LR-UCAs BAMF Relocation w/ 12" 2.5 King Pelfreybilt Armor: Bumper, Skids, Sliders Prinsu Roofrack ARB Snorkel & Twin Compressor sPod
    Could you help a friend out with some more info on this? I'd like to go this route
  20. Nov 15, 2017 at 7:30 PM
    #40
    Larl
    Larl Member
    Chicago-Land
    Thanks, but I've never discussed pheasants before.
    CusterFan likes this.
