Remote start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RedWings44, Aug 27, 2020.
  1. Aug 27, 2020 at 8:33 PM
    RedWings44
    RedWings44 [OP] Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I appreciate it and will be sure to reach out if I want to try that one. And no, I don't have the MT either. (Unless you didn't mean manual transmission)
    wahoobie[QUOTED] likes this.
  2. Aug 28, 2020 at 1:27 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Correct, paid yearly. At 39.95, that breaks down to about $3.33 a month and at $99.95 (saves you $20) the breaks down do about $2.77 a month. I lose more coin in my couches a month or spend more on a single cup of java at the coffee shop than that. It is not a contract like your cellular service which binds you because of the co-pay (or full cost coverage) they cover on a new smart phone when you get it discounted or free. They have to bind you into a contract that has an early termination fee because someone has to pay for that phone...and it will always be YOU whether upfront or in increments until they recoup the cost of the device. With the smart module, if you don't pay the subscription after the first free year, not problem; You just have a paper weight in your car until you do. However, most people don't know that insurance companies, at their discretion based on vehicle and zip code give discounts (per month) of $10 - $20 for having a GPS tracking device (which ours does in addition or remote start/stop, lock and unlock which means that in a year or so, your device will have been paid for, and your subscriptions per year would be covered in 2-4 months each year with the rest of the savings going in your pocket. Basically it will be free after your first year and some change.
    You wedge a 2 x 4 and walk away. You can't. That's what the clutch cancel or clutch bypass is for.
    Incorrect. It's a little bit more autonomous than that. When the remote start is triggered via 3X lock presses on the OEM fob, our module will send a signal to "simulate" the clutch cancel signal, then we remote start the vehicle. We also have procedures in place to avoid starting in gear, ever. Dummy and fool proof.
    ??? Not sure what that means, but sure...
    The Smart Start by Viper/Directed costs $99.99 a year...not cheap compared to our $39.95 a year for the same 4G/LTE speed with same command functions within the smart phone app. Lowest yearly rate in the market.
    That's the only thing we want for you as well which is why if your cannot do it from an OEM fob, we won't sell it. No need to bulge out your pockets or carry anything extra that can be potentially lost, more than what you already have now, OEM fob and phone.
  3. Aug 28, 2020 at 4:08 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    My comment had nothing to do with you, wasn't directed at you, thats why u don't understand it. Had nothing to do with you.
    N2DesignsInc[QUOTED] likes this.
  4. Aug 28, 2020 at 4:29 AM
    JRhue
    JRhue Well-Known Member
    Glen Burnie, MD
    2019 Cement Tacoma TRD Offroad
    Bilstein 5100s OME 888 JBA UCA OME HD leaf pack RRW RR6-H 17x8.5 -12 BFG K02 285/75r17
    I have the N2 remote start kit. I mainly went with it because it used the factory remote and it was all plug and play. It took me less then 15 mins to install. The only thing that sucks is the factory remote distance isnt great but thats not fault of the remote start.
  5. Aug 28, 2020 at 6:53 AM
    RedWings44
    Michigan
    Thank you for the information!
  6. Aug 28, 2020 at 7:04 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I agree the range on the stock remote sucks. It's why I added the cell module later. I'm happy with it. Only thing I don't like is the engine turning off when you open the door but that's Toyota's fault not N2.
    RedWings44[OP] likes this.
  7. Aug 28, 2020 at 7:12 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    FYI - My keyed (SR5) auto and the iDataStart unit does not suffer from the door opening engine off.
  8. Aug 28, 2020 at 7:35 AM
    RX1cobra
    19 OR
    Correct. I should have clarified; the door turning the engine off is push to start thing.
  9. Aug 28, 2020 at 7:41 AM
    RedWings44
    Michigan
    I was just about to ask if I could add that later if I wanted.
  10. Aug 28, 2020 at 8:28 AM
    SciFiGuy
    SciFiGuy Member
    Go with Accessorides for remote start, they make a bunch of neat little harnesses and stuff for our trucks, not just repackaged fortin products, plus they employ veterans. Fast plug and play remote start installation :)
  11. Aug 28, 2020 at 9:37 AM
    db6598
    db6598 Well-Known Member
    NC
    I'm satisfied with the N2 unit with cell add-on. I would say if you live in an area with less than stellar cell service that add-on unit may not be super reliable. I've noticed sometimes it doesn't connect to my app if I'm in an area like that. My normal "home" area its fine though.
  12. Aug 28, 2020 at 11:47 AM
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
    You know you can touch your head with the remote while activating it and it will add distance to it.
  13. Aug 28, 2020 at 11:51 AM
    RedWings44
    Michigan
    I will look into them. Do they use the factory remote?
  14. Aug 28, 2020 at 12:08 PM
    Darth_Smittious
    Darth_Smittious Active Member
    2015 Tacoma PreRunner SR5
    Fox 2.5 DSC Coil overs, Icon Delta Joint UCA,'s, Fox 2.5 DSC Shocks, Full Icon RXT leaf pack, Archive Garage Flip with 2.7″ Super Bumps
  15. Aug 28, 2020 at 12:57 PM
    #35
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Is this a Friday response? :lalala:
  16. Aug 28, 2020 at 1:00 PM
    #36
    PilotguyPA28
    Trip
    No it’s true. Go out and test it. Go away from your truck until your remote doesn’t work. Then touch it to your head and white in contact with your head try it.
  17. Aug 28, 2020 at 1:01 PM
    #37
    Kairide
    2020 White SR5
    I might get arrested, I don't know where you're from, but in the city they frown upon that type of behavior in public. :rolleyes:
  18. Aug 28, 2020 at 1:03 PM
    #38
    PilotguyPA28
    Trip
    Google it. There are many articles written about it.
  19. Aug 28, 2020 at 1:04 PM
    #39
    Kairide
    2020 White SR5
    It is Friday...why not.....
  20. Aug 28, 2020 at 1:26 PM
    #40
    PilotguyPA28
    Trip
    And I’ve done it myself. It definitely works.
