Remote start?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020CementGrey, Nov 15, 2022.
  1. Nov 15, 2022 at 3:31 PM
    2020CementGrey
    2020CementGrey [OP] New Member
    Garrick
    2020 Cement Grey Tacoma TRD
    Once I press the lock button 3 or 4 times on the key fob the truck will flash the park lights a few times an then start but when I get up to it an open the door with the sensing handle an the key fob in my pocket the truck will then shut off so my question is does everyone’s shut off an do that an if not how do I keep it from doing that
  2. Nov 15, 2022 at 3:33 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It does.
    You can't.
    Unless you install aftermarket starter
  3. Nov 15, 2022 at 3:34 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    yes it shuts off when open a door.
    Seems it’s a Toyota Lexus thing not sure anyone has found a way around it.
  4. Nov 15, 2022 at 3:40 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Welcome, this comes up weekly if not more often during the cold months, I’ve never heard of a fix.
    2020CementGrey[OP] and Kllrbee like this.
  5. Nov 15, 2022 at 3:50 PM
    Ole No. 1
    Ole No. 1 Well-Known Member
    2023 TRD OR DCSB 4WD
    Normal operation. Stupid design.
  6. Nov 15, 2022 at 6:04 PM
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    i have an A/M does the same thing. Has something to do with the connection under the steering wheel cover. Its a safety thing so no one steals your truck. Also the truck will remain locked so no one can just get in it.
  7. Nov 15, 2022 at 8:52 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    ^^- This.
  8. Nov 15, 2022 at 9:46 PM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    This. Even Ford solved forever ago on all push-to-start cars. I still appreciate a warm truck in the morning, but doubling my starter usage not so much.
    2020CementGrey[OP] likes this.
  9. Nov 15, 2022 at 9:48 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Does this work on all Tacomas or just newer ones? I’m too lazy to dig out my key fob and try it.
  10. Nov 15, 2022 at 9:50 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Yeah I was quite disappointed when I found this out, even called the dealership asking if I should bring it in to be looked at. I use it when needed, which tends to be sparingly as if its that cold outside (below -10C) then I'm usually wrapped up anyway.
  11. Nov 15, 2022 at 9:54 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It won’t cause any appreciable added wear and tear to the starter, definitely not something to be worried about.
