Remote Starter Install gone bad, please help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacosian, Dec 16, 2024.
  1. Dec 16, 2024 at 9:30 PM
    tacosian
    tacosian [OP] New Member
    2021 Tacoma SR5 Double Cab
    Tweeter Speaker Swap DS18 PRO-ST
    I purchased the x start off Amazon thinking that the “plug and play” description would be in line with my abilities. I’ve done a couple speaker or stereo swaps (ds18 tweeter swap, jeep commander stereo and speakers) so thought I’d give it a go.
    Was most of the way there until I came across the splicing in portion. Supposed to splice into the TPMS wire for some sort of trickery with the receiver I guess. Found out the hard way there’s less than enough free wire to do so.
    Where I’m at now:
    - Remote starter worked briefly, now does not.
    - Tire pressure light is always on cause the splicing didn’t happen.
    - Headlights/Cabin lights don’t turn off or on when I enter or exit the vehicle due to what I believe is some wiring folly’s with the door ajar sensor (door ajar alert not responding). May have unplugged something or damaged something when doing all this panel removing.
    Can someone tell me if I’m completely screwed or if I can fix this one step at a time. (If you’d outline those steps that’d be great as well).
  2. Dec 16, 2024 at 9:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    tacosian[OP] likes this.
  3. Dec 17, 2024 at 5:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The good news is; you know exactly where the molestation happened, so get back in there, inspect and repair.
  4. Dec 17, 2024 at 5:55 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Patch and repair the wire? Don't know what else to tell ya.
    wilcam47 and Chew like this.
  5. Dec 17, 2024 at 6:44 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    :popcorn:
    RIX TUX likes this.
  6. Dec 17, 2024 at 6:47 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I would completely undo the install.
    eurowner, Phlogiston, BOMBS and 5 others like this.
  7. Dec 17, 2024 at 6:55 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Also, many suggest disconnecting the battery before working on electrical systems. I would take the extra precaution since you think you may have botched the wiring. Better safe than sorry.
  8. Dec 17, 2024 at 7:04 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Toyota’s are a little tricky. I needed some pigtails that were not included in my starter kit. Complicating it further was the Maestro & alarm install at the same time. Took better part of a day to install but worth it.
    wilcam47 likes this.
  9. Dec 17, 2024 at 9:38 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    My old brain isn't understanding. Why can't you just lengthen the wire ?
    auskip07 likes this.
  10. Dec 17, 2024 at 10:04 AM
    kerrybro
    kerrybro 16 tacoma TRD
    kerry
    ontario canada
    2016 Tacoma TRD sport
    I just installed the start-x remote start in my 2016 in half an hour and it was plug and play. Nothing to do with TPMS !!??
  11. Dec 17, 2024 at 10:14 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You should post the link to what you ordered. Usually, plug-and-play means no wire splicing lol.
    lastcall190 likes this.
  12. Dec 17, 2024 at 10:15 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    if you've got an SR5, that's an automatic. Are you sure you needed to cut the TPMS wire? If I remember correctly when I did my N2 install (7 years ago), cutting that wire was just for the manual transmissions.
    Could be wrong about it, but worth double checking which set of instructions you used.
    Jaredius likes this.
  13. Dec 17, 2024 at 10:48 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I think the TPMS wire cut is push to start vs key. Key = cut; PTS = no cut.
  14. Dec 17, 2024 at 10:51 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    ok there you go - and all the manuals are keyed, which is why I had to do it.
    Are the SR5s push-to-start?
  15. Dec 17, 2024 at 10:56 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    @N2DesignsInc may have some input - I bought for a 2020 early on in the 2020 roll out, and they had a splice in theirs then. The N2 kit no longer splices wires, but I was in that window where they were splicing.
    If I remember correctly (this was 5ish years ago now) the kit I bought from N2 had something like this for the splice:
    https://www.homedepot.com/p/WAGO-27..._rYHJbkR8PqS4RIF1SqVWyd79P8_xStTNMWndpU&gQT=1
    It worked right after install, and hasn't skipped a beat since.
    doublethebass likes this.
  16. Dec 17, 2024 at 11:48 AM
    RX1cobra
    19 OR
    They changed to pts late in the production run. I don't recall exactly when and dont care enough to look it up. :rofl:
  17. Dec 17, 2024 at 3:22 PM
    tacosian
    https://www.amazon.com/dp/B07M75Z8W3
    https://youtu.be/Vn7FWoQyuDw?feature=shared
    here’s the links to both the starter and the video that the directions had a QR code link to. For additional context I do have the manual key in my 21 not the push to start. I believe the SR5s switched to push to start in 22, or maybe a mid production change not sure.
    Called a place today to see how much it’d be to get one installed and to remove the other one, quoted me at $350. Wondering if they’d be able to fix whatever else is going on as well or not.
  18. Dec 17, 2024 at 4:02 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why do you need a remote start?
    sounds like a mess now
    is it worth all this?
    Phlogiston likes this.
  19. Dec 17, 2024 at 4:06 PM
    tacosian
    Michigan winters and I don’t have a garage. Definitely a nice to have not a need to have. I figure I’m already here, should at least get the original goal accomplished.
  20. Dec 17, 2024 at 4:12 PM
    FastEddy59
    Eddie
    I start mine from 30+ stories up. Kinda have to aim the fob but hasn’t let me down yet even in Fog.
