Remote starter problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nalex, Nov 13, 2017.
  1. Nov 13, 2017 at 7:48 PM
    Nalex
    Nalex [OP] Well-Known Member
    2012 Tacoma DC TRD OffRoad
    I got a remote starter installed today at Best Buy. Everything went well according to them. On my way home, the Check engine light and the Trac light went on. Also when I shift from P or N to D the transmission takes few secs to engage then it jerks. Except for that it runs smooth and transmission shifts fine.
    I picked up the truck right before they closed so i wasn't able to get in touch with them. I am going to give them a call tomorrow. But I am afraid that they may mess up something if they try to figure out the problem. Any ideas about what might be the problem?
    Thanks
  2. Nov 13, 2017 at 9:57 PM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    Nalex[OP] likes this.
  3. Nov 15, 2017 at 8:26 PM
    Nalex
    Update.
    So I took it back to Best Buy. The truck was showing p0705 code. They removed the remote starter, cleared the code. But it did not help. Check engine light came back and the transmission still not shifting right.
    They acknowledged the issue and advised me to take it to the dealer.
    I did some search and found some threads/posts about people having similar problems, but none had a definitive solution.
    Let's see what the dealer is going to say.
  4. Nov 15, 2017 at 9:00 PM
    Muddinfun
    Muddinfun Well-Known Member
  5. Nov 19, 2017 at 5:35 PM
    Nalex
    So, the remote start was removed completely. The truck is normal now and dash lights gone.
  6. Nov 19, 2017 at 5:49 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Try this
  7. Nov 19, 2017 at 8:03 PM
    Nalex
    Honestly, I'm afraid to even try. I would like to have a remote start, but do I need it? Not really.
    Any DIY instructions on this? Any problems?
    Just in case I changed my mind.
  8. Nov 19, 2017 at 8:27 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    I have viper remote start .. no issues.
