Remote Starter ??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harp1, May 30, 2025.
  1. May 30, 2025 at 6:43 PM
    Harp1
    Harp1 [OP] Well-Known Member
    Masshole for now
    2022 Toyota Tacoma DCSB
    purely stock
    Yesterday I hit the remote starter fob to start my truck and it kept cranking. Did this cycle 2 times and never started. I then went outside and manually started the truck with my keys. It definitely cranked for 5-6 seconds before finally starting. The truck did this last year once so I waited to post about it unit it happened again and obviously it happened. I've had zero issued since purchasing my truck brand new. Just curious if this has happened to anyone and well what should I do?? Thank You
  2. May 30, 2025 at 6:47 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    take it to a mechanic
  3. May 30, 2025 at 8:45 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Happens with me 1 time in 6 months regardless of weather or any other conditions (!!!)
    Second attempt (by the remote starter automatically or manually by the key) it starts after 3-4 seconds of cranking.
    Have no idea wtf is that. Truck is 2019 TRD OR AC LB, 6M, Autostart remote start system (using daily year around).
    Happens for last 3 years
