REMOTE STARTS: for 6M/T..and something else
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NickyDrops, Feb 12, 2024.
  1. Feb 12, 2024 at 2:45 PM
    NickyDrops
    NickyDrops [OP] Member
    Hello All,
    Any suggestions for a remote start for a 2020 stick? Also, best place to run wires through the firewall.
    Thanks!
    NC
  2. Feb 12, 2024 at 2:59 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I hope you realize that if you remotely start a 6mt truck while it’s in gear that it will proceed to drive off without you and crash into anything in its path, possibly killing someone, and landing you in prison?
    eurowner and Cetacean Sensation like this.
  3. Feb 12, 2024 at 3:08 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Jimmy at N2 Designs.
    2020SilverSky likes this.
  4. Feb 12, 2024 at 3:10 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Big if true!
  5. Feb 12, 2024 at 3:41 PM
    SmartyMcFly
    SmartyMcFly 88 MPH
    2023 TRD Off Road 4x4 Ice Cap
    Why can’t somebody make a remote start that senses if the cars in gear and deactivates itself? How hard can it be?
  6. Feb 12, 2024 at 3:44 PM
    gudujarlson
    Minnesota
    The 6mt does not report what gear, including neutral, it’s in (please correct me if I am wrong). There is however a switch on the clutch that prevents the truck from starting unless the pedal is depressed to the floor. This can be disabled via the clutch start cancel switch.
    Chew and Cetacean Sensation like this.
  7. Feb 12, 2024 at 3:44 PM
    Cetacean Sensation
    PNW
    Most cars don’t directly know what gear they’re in.
    They extrapolate that info at speed by comparing the vehicle’s speed to its engine RPM in a lookup table.
    If the car isn’t moving, it has no idea what gear it’s in (barring Reverse, obviously).
  8. Feb 12, 2024 at 3:47 PM
    gudujarlson
    Minnesota
    I’m assuming the automatic transmission reports whether it’s in park, neutral, or drive/s-mode, because things like remote start and 4lo depend on it.
  9. Feb 12, 2024 at 3:50 PM
    NickyDrops
    Well I wouldn't want to look like a complete idiot... but yes.. well aware.
    Cetacean Sensation likes this.
  10. Feb 12, 2024 at 3:52 PM
    NickyDrops
    correct! It has the switch... I totally get it... liability.
  11. Feb 12, 2024 at 3:55 PM
    gudujarlson
    Minnesota
    Manual transmissions don’t have a “park” position. Instead it is standard practice to park them in either 1st or reverse gear to prevent them from rolling away. This is not compatible with remote start.
  12. Feb 12, 2024 at 3:56 PM
    Cetacean Sensation
    PNW
    Youre right, automatics do directly know where the PRNDL is, but this is a thread about manuals so I didn’t want to muddy the explanation by also talking about automatics.
    Modern automatics are full of sensors and directly know what gear they’re in.
    For 4Low, that’s also why stick fourwheelers tell you to put the clutch in, because the manual doesn’t know if you’re in neutral or not, but it knows if you have the clutch depressed.
    NickyDrops[OP] likes this.
  13. Feb 12, 2024 at 3:59 PM
    NickyDrops
    the practice is to use the parking break...using gears and/or turning wheels to curb used for parking on hills. Im just curious if anyone installed one.
    oconnor likes this.
  14. Feb 12, 2024 at 4:01 PM
    Cetacean Sensation
    PNW
    There are plenty of people who have flat places to park and never leave it in gear. I don’t agree with them, but it’s pretty common and those folks will have no issues installing and using a remote start.
    That one time they forget they left it in gear though? Well that’ll get you on the news at least. https://www.wxyz.com/news/region/oakland-county/video-remote-start-sends-car-into-pond-in-new-hudson
  15. Feb 12, 2024 at 4:02 PM
    gudujarlson
    Minnesota
    If you leave your truck in neutral while parked and rely on the parking brake, I think you are in the minority, albeit I’ve never seen a survey.
    Personally I leave it in gear 100% of the time and use the e-brake for extra protection on slopes. E-brakes are not always in full working order on old vehicles and that cable could always snap.
  16. Feb 12, 2024 at 4:04 PM
    SmartyMcFly
    SmartyMcFly 88 MPH
    The addition of a simple sensor that verifies the car is in neutral is all that is needed. As far as stoping the car from rolling away. Might have to get some wheel chocks or something. I’m not saying that I would park my manual vehicle without it being in gear I’m just saying there’s just one extra step of adding a sensor somewhere and remote start should work fine
  17. Feb 12, 2024 at 4:07 PM
    NickyDrops
    I definitely agree with them being (or not) in working order...
  18. Feb 12, 2024 at 4:12 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There are manufacturers for remote start on a MT. Before you turn the truck off, you have to go through a shut down process that allows the remote start know that the shifter is in neutral and the e-brake is set. If anyone opens a door before the remote start is activated after the shutdown process it won’t start the truck. Compustar is one brand.
    Benny blanco and NickyDrops[OP] like this.
  19. Feb 12, 2024 at 4:21 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    N2 designs does a good one for the 6MT. I’ve had it for 6yrs+
    It won’t let you start in gear because you have to “set” the remote start in neutral before you leave the truck. The sequence is drive along, park the truck, shift to neutral, pull the hand brake, foot off the foot brake, twist the key too the “off” position and pull it out - but the engine still runs. Then you get out of the truck and when you shut the driver door it locks and the remote start is set. If you open any door it deactivates. Might even deactivate if you just unlock the truck, but I can’t remember. Then just push lock 3 times, slowly, and she starts. Truck is locked the whole time and can’t roll away because you left it in neutral and had the hand brake on.
    oconnor, NickyDrops[OP] and vssman like this.
  20. Feb 12, 2024 at 4:46 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Like someone said try Compustar 2 way and have a good professional install it.
