Remote tailgate lock question....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020TacomaGuy, Jun 27, 2022.
  1. Jun 27, 2022 at 2:42 PM
    2020TacomaGuy
    2020TacomaGuy [OP] Well-Known Member
    2020 4x4 DCSB SR5
    Will the key work even if the actuator fails? I would think so.
    thanks in advance for info.
  2. Jun 27, 2022 at 2:52 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Interesting question. I'm sure it does. I will try later.
    Another interesting thing I learned about this lock on my truck: the tailgate lock ONLY works with key fob. If I try to unlock the doors with the unlock button on my door, it doesn't work. Is this normal?
  3. Jun 27, 2022 at 2:54 PM
    sunnyboy
    sunnyboy Well-Known Member
    Tacoma TRD Sport
    Yes. They both operate the same mechanism but will work independently.
    PhogDog likes this.
  4. Jun 27, 2022 at 2:57 PM
    sunnyboy
    Tacoma TRD Sport
    Odd. Mind you my experience is with the factory add-on kit, which has a harness extender that plugs into the passenger front door lock/unlock circuit, so it works whenever the passenger door is locked/unlocked, whether by button or fob. Mine's in a 2019 Sport but the kit is universal - though you do have to order for the bed size as wire lengths differ.
  5. Jun 27, 2022 at 3:02 PM
    MTB_Tacoma
    MTB_Tacoma Well-Known Member
    2022 Electric Lime Tacoma TRD Pro MT
    Mine (OEM) works in sync with buttons, remote and keyhole entry. If I double press the remote unlock button, it unlocks. If I double turn the key in the door keyhole, it unlocks. If I unlock once with my remote and unlock doors with the button inside the door, it unlocks.
    The only bad behavior is if I use the remote to unlock everything and only open the tailgate, everything will lock by itself a few moments later (thus if I leave the key in the bed and close the tailgate, I’m out of luck - bed cover on and locked truck/tailgate).
    sunnyboy likes this.
  6. Jun 27, 2022 at 9:58 PM
    caribe makaira
    Caribbean, Puerto Rico
  7. Jun 27, 2022 at 10:29 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    It's tied into the front passenger door lock. You need to hit the button that unlocks all the doors. If it's doing this with the fob hit unlock twice. You can change the lock/unlock settings through your headunit.
  8. Jun 27, 2022 at 10:56 PM
    guest_707
    guest_707 Well-Known Member
    Wait... Do all tacomas come with remote unlock tail gates? Mine doesn't unlock/lock unless I stick the key in. I just got my truck last week and still learning all the stuff it has (trd off road premium)
  9. Jun 27, 2022 at 11:38 PM
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    No the locks are accessories.
  10. Jun 28, 2022 at 5:44 AM
    MTB_Tacoma
  11. Jun 28, 2022 at 5:51 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I would imagine that's the "fail safe" method to use...the capability isn't removed after installing the tailgate lock.
  12. Jun 28, 2022 at 6:02 AM
    caribe makaira
    It's very clear you do not understand.:rimshot:
  13. Jun 28, 2022 at 6:05 AM
    MTB_Tacoma
    I understand the lock is useless to protect against those who really want to get in (and know the trick), but my statement was about my own problem of locking myself out.
  14. Jun 28, 2022 at 6:40 AM
    2020TacomaGuy
    2020 4x4 DCSB SR5
    Thanks
