Remote Tailgate Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Habie, Sep 25, 2021.
  1. Sep 25, 2021 at 1:42 PM
    tacosandnoodles
    tacosandnoodles Member
    Denver, CO
    2018 TRD OR DCSB
    Just installed the Pop & Lock. Easy install. Follow instructions on Youtube. Wire to the driver side to unlock with one click on your remote, wire to passenger to unlock with double click on remote. Definitely recommend it. Oh and double check the model numbers. The newer ones have plug and play harnesses that make it extra easy.
  2. Sep 25, 2021 at 1:52 PM
    oneup714
    oneup714 Well-Known Member
    All show no go Super White Tacoma TRD Mall Crawler
    Installed the pop n lock on my truck, should have done this mod 1st. Took me less then an hour. It took longest to run the wires cleanly than installing the actual mechanism
  3. Sep 25, 2021 at 2:08 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    PA
    2019 Off Road Looooooooong Bed
    Another thumbs up for the OEM. Hardly any effort to install, so definitely worth it. Took me less than an hour to install mine in the driveway earlier this year. Nothing special needed, although a creeper would make the process even more painless when your under the vehicle. I did mine without.
    pnw_pro_taco and mic_sierra like this.
  4. Sep 25, 2021 at 2:12 PM
    M1crazy
    M1crazy Active Member
    Barry
    Hillsboro MO
    2023 Access CabL TRD OR 4x4 AT Ice Cap
    I went with pop n lock mainly because of price. Believe it or not I like the loud sound of the lock at least I know by sound it is working.
    Barry In MO.
    ORtoCOTaco likes this.
  5. Sep 25, 2021 at 3:52 PM
    kekkan
    kekkan Well-Known Member
    Kevin
    Southern New Hampshire
    2021 Cement TRD Sport DCLB
    I can confirm, picked up the OEM unit from Toyota yesterday. $165 installed today about 45 minutes, hardest part was cable tying the cable under the truck which is still pretty easy
  6. Sep 25, 2021 at 3:58 PM
    clock11
    clock11 Well-Known Member
    Aaron
    Southern California
    2020 White TRD Off Road
    Deaver Stage III, Icon Stage 3 (minus Icon leafs), BFG K02s, Prinsu roof rack, Diamondback HD, CaliRaised Ditch lights and Brackets, Clazzio Seat Covers, Rearseat 12v Power & USB, Bed cubby 12v Power & USB, Interior LED bulbs, Toyota OEM tailgate lock.
  7. Sep 25, 2021 at 4:03 PM
    Galaxytitan
    Galaxytitan New Member
    Andy
    Phoenix
    2021 red trd off road dclb
    3" lift 285 Yokohama G003s victory 4x4 roof rack
    I went toyota I want it to last forever like the rest of the truck
  8. Sep 26, 2021 at 5:22 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
  9. Sep 26, 2021 at 6:05 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    At the time I got mine, the PopNLock WAS what the dealer was installing, and I am not sure that what they are installing now is or is not the PopNLock! But in any case, yes, in 2018 and 2019, if you wanted to install this, Toyota had their own part# for it but when you received it, it actually came in a PopNLock box but with the toyota part number on it! Look at the thumbnail for my video, and you will see, it is a PopNLock box, but the Toyota part# is right there! In fact, when I ordered mine, it was not even an option here on the west coast, but a special option only available at the time, to dealers in the Southeastern US Toyota zone. I ordered mine from a dealer in NC, as I had a friend there and I wanted him to get some credit. And like others here, I just paid my local mechanic an hour's labor to install it for me. But installing this was a good thing, as using that stupid key in the fob is a pain in the butt for me, as I keep my fob wrapped in plastic to protect it. yeah I know, if the battery goes down and I am not at home, then I will have to take the key out in order to open the door and then use the fob to start the engine, but I am ok with that.
    WhiteTaco20[QUOTED] likes this.
  10. Feb 15, 2022 at 12:20 PM
    rlynch03
    rlynch03 Member
    2019 Gray Tacoma TRD Sport
    Predator Tube Steps Step Tubes, Bed Step,
    Is there a cheaper alternative to this sealant? Don't mind spending a few extra bucks but $35 for this sealant seems like alot.
    3M Ultrapro Autobody Sealant, 08302, Clear Color, High-Solids, Heavy-Bodied, Fast-Curing, Solvent-Based, 5 oz Tube
    Ordered the OEM Tailgate Remote Lock and OEM Bed Lights. Plan to install together.
  11. Feb 18, 2022 at 6:11 AM
    Sharperspoon
    Sharperspoon New Member
    2018 Tacoma TRD Sport 6MT
    I installed a tailgate lock for like $20. 15 feet of braided loom, some left-over aluminum ducting tape, a spool of 16 gauge wire I had laying around, an actuator from an old project, some wire taps and some heat-shrink.
    Run the new wires through the tailgate camera harness, add a quick disconnect for the 2 new wires. Loom it. Zip tie it. Metal zip ties near exhaust.
    Routing the harness from the tailgate to the cab was the worst part. That is something you'd have to do with the OEM kit anyways.
    It wasn't hard and saved me over $200 CAD.
  12. Feb 18, 2022 at 7:50 AM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I am curious for those that have installed the OEM kit, does the actuator just add on to the mechanism or replace it? In other words, can you still manually lock/unclock with the key if you had to? Thanks in advance and for the other info here - I definitely want to add this at some point
  13. Feb 18, 2022 at 8:22 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    OEM or aftermarket, the key still functions. Just like your driver door. The power lock functions or the key functions.
  14. May 3, 2022 at 8:16 PM
    mac_hine82
    mac_hine82 Member
    2022 Tacoma SR
    I have a 2022 SR 4cyl. Reading through the installation manual for PK3B6-34JS0 it mentions conflict with the bed lighting kit. Wonder what it is? I just installed the bed lights and it works great, I love it. Anyone have information on that or any difficulty?
  15. May 3, 2022 at 9:06 PM
    #35
    Gametracker
    Gametracker Well-Known Member
    Fort Worth, Tx
    17 sport TRD 4x4
    SSO Hidden winch bumper, Meso puddle lights,
    I did mine by ordering a servo off of Amazon. Took 30 min. make it nice with the bed cap.
  16. May 4, 2022 at 8:38 AM
    #36
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The instructions linked are for a Tundra.
  17. May 4, 2022 at 8:48 AM
    #37
    COMMANDO740
    COMMANDO740 Well-Known Member
    Southernahia
    2022 TRD OFFROAD MAGNETIC GRAY
    This is the project that is on my list next. Sounds like a must have for security.
  18. May 4, 2022 at 8:51 AM
    #38
    3Marcus3
    3Marcus3 Member
    Marcus
    Long Island NY
    2022 Mag Grey Tacoma Sport Access Cab 6MT
    I'm another that did the OEM remote lock. The only thing I'll add is that when routing the cable through the tailgate, if you remove your tailgate and place it on something flat behind the truck, you can straighten the feedthrough cables (lock and camara) to make installation of the feed though plastic bushings/gromets much easier.
  19. May 4, 2022 at 8:54 AM
    #39
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    R4T version is quiet. I've got this one installed, no sound deadening material needed.
  20. May 4, 2022 at 10:58 AM
    #40
    Gametracker
    Fort Worth, Tx
    17 sport TRD 4x4
    I never had any issues on mine..
