Remote Tailgate Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PeppazTaco, Mar 8, 2022.
  1. Mar 15, 2022 at 11:00 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    [/QUOTE]
    I took a few small pieces of leftover Dynamat and placed them inside the tailgate to mute some of the resonance . It still “clicks” but doesn’t “Claaank”.
  2. Mar 16, 2022 at 2:30 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have the Toyota OEM kit, very quiet compared to the PopnLock brand we had in the old 2015 Tacoma. I put foam insulation in mine and you can barely hear it.
  3. Mar 24, 2022 at 9:07 AM
    JonWVBFL
    JonWVBFL New Member
    2022 - SR5, DCSB.
    I just placed an order at my local Toyota Dealership for the part: PK3B6-35JS0, and I provided my VIN with the sale. Well, they just called saying that this part does NOT fit the '22, and then they stated that the part # that does is: 00016-34355.
    I searched that number and a similar part showed up on Sparks Parts (https://www.sparksparts.com/p-tailgate-power-lock-0001634351) and looking at this install PDF for that part # (http://toyotaparts.sparkstoyota.com/install/00016-34351-taco21.pdf) the difference in the 51 & 55 could be the remote key-less entry (with the 51 for trucks WITHOUT). Big difference I see so far compared with the PK part is that it runs up the Driver's side.
    I will have it tomorrow with a possible install happening this weekend. I'll get a copy of the instructions from the dealer also. I can report back how it goes!
    TheWeatherman and JJ Diablo like this.
  4. Mar 24, 2022 at 4:00 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    For anyone installing the factory kit, there is a guy needing the plastic pieces that holds the camera wire in place. The kit provides two more clips and says discard the ones for a single wire. If you have some, help him out.
    I just installed mine the other day but threw away the clips. The kit is nice and takes an hour or so to install. Very nice setup and works great.
    Jon
  5. Mar 26, 2022 at 8:39 AM
    TacoCarl303
    TacoCarl303 Well-Known Member
    +1 for Pop & Lock, had it and worked great for 4 years.
  6. Mar 26, 2022 at 7:43 PM
    Froth
    Froth Well-Known Member
    fred
    2016 taco
    So far I have done 3, first was a popnlock, the second was the OEM one, and the third was from runnin for Tacos, you can actually just melt a hole with a soldering iron for the cable if you don't have the kit...all were the same, plug n play, it seems that some come with additional inline fuses and some don't.
  7. Mar 27, 2022 at 6:32 AM
    zfeen24
    zfeen24 Active Member
    2022 magnetic gray tacoma SR5
    None yet
    Anyone know of a link for one that’s compatible for the 2022 sr5 access cab with the 6’ bed?
    Thanks
  8. Mar 29, 2022 at 11:17 AM
    cmac6750
    cmac6750 Well-Known Member
    Charlie
    Cottage Grove, MN
    2022 SR5 DCSB Blue Crush Metallic
    I am also looking for a compatible one for 2022 SR5 DCSB...
  9. Mar 29, 2022 at 5:41 PM
    hk24
    hk24 Well-Known Member
    Lynn
    2022 TRD Off Road DCSB
    I got my OEM tailgate lock on ebay for $135 shipped with taxes. Works great.
    Lynn
  10. Dec 18, 2022 at 11:04 AM
    Robie
    Robie Member
    Robie
    French Valley, CA
    Silver 2018 TRD Off-Road 4x4
    2018 Silver Tacoma
