Remote Window Roll Up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RedManRocket, Mar 8, 2017.
  1. Mar 8, 2017 at 2:18 PM
    RedManRocket
    RedManRocket [OP] Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I'm having an issue, I'm trying to figure out how to get my windows to roll up remotely, my audiovox has a negative latching aux input and I've managed to get power to the master switch and I can now roll the windows from the switch while the truck is off , but how can I get the windows to move now? I thought I've tapped into the correct wires but obviously not, what am I missing? Does it need to be positive? Negative? Low current negative? Any input would be great, @BartMaster1234 do you happen to have an idea of what wires I need to tap into? Thanks in advance!!
    BartMaster1234 likes this.
  2. Mar 8, 2017 at 2:24 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Here's the wiring diagram for your model year, ignore the notes (that's how you make it work in the absence of the integration module). You should be tapping into the switch wires if I'm not wrong.
    Try asking @mechanicjon, I would have no idea what I would be doing if it wasn't for him. Lol.
  3. Mar 8, 2017 at 2:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oph my B. That's the single/extended cab diagram. Here's the PDF for your Double Cab.
  4. Mar 8, 2017 at 2:34 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Yeah, I have those diagrams. I've tapped into every wire every which way trying to get it to work, I can push the switch and it will go, but why when I add power I get nothing, not even the wire reads 12v it's like it's not letting power get in, I guess I could try to tap directly into the motor maybe
  5. Mar 8, 2017 at 6:38 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Let me study diagrams
  6. Mar 8, 2017 at 6:59 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    with a negative latching signal. At times you may be rolling up 4 windows at once. There is now way to do that thru the switch. You need an external relay that the signal will work. Then all the motors power up side of the motor will be tapped into it. Also you'll need 4 diodes. However you got power to the windows key off. Undo it. I'll make up a diagram for you.
  7. Mar 8, 2017 at 7:28 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Okay, thanks!!! And I already have the four diodes wired in
  8. Mar 8, 2017 at 7:29 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Nd
    And the relay, but I have it sending 12v I'll change it to a negative
  9. Mar 8, 2017 at 7:45 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    no don't change it
  10. Mar 8, 2017 at 7:46 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The negative signal will be to control the relay
  11. Mar 8, 2017 at 7:56 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I'm going to have to think about this one for awhile. The problem with just wiring into the up side of the motor is that the wires are grounded when not in use. So putting power to it would feed back into the switch causing a short.
  12. Mar 8, 2017 at 8:05 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Yeah it had me a little stumped too, I was thinking maybe I'd have to tap into motor wires directly at all four doors, but we'll see what you can come up with. Probably much better than what I'll try to do
  13. Mar 9, 2017 at 2:57 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    You will need a total of 5 relays and some 12 or 14ga wire.remote roll up.jpg door switches1.jpg
    cruiserguy likes this.
  14. Mar 9, 2017 at 3:02 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Here's the 2 pictures in a zip file you can download and zoom in one them a little better
  15. Mar 9, 2017 at 3:27 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Get a 535T. Makes it really easy. Remote roll up/down and turns power windows into one touch up/down. One module does two windows. If you have a double cab you'll need two modules to do all four windows.
    https://www.amazon.com/gp/aw/d/B00H4N1Y2O
  16. Mar 9, 2017 at 10:03 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Do you happen to have a wiring diagram? I have no experience with the 535T. Are you using it? How was it wired in? I wouldn't mind putting one on my DC.
    loginfailed[QUOTED] likes this.
  17. Mar 9, 2017 at 11:13 AM
    BartMaster1234
    Tyler
    Flux Capacitor
  18. Mar 9, 2017 at 11:16 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Here the installation manual. Looks like it uses an Aux channel on your security/keyless entry system. http://pdf.ampire.de/directed/535T_englisch.pdf
    loginfailed likes this.
  19. Mar 9, 2017 at 1:55 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don't have one currently, but I've installed tons of them over the years. It used to be called the 530T. And there was a single channel 529T you could use for sunroof control.
    It wires in-line with the window motors. So you basically cut the window motor wires. Two of the wires from the 535T go to the switch side of the wires and two to the motor side. Then there's power and ground plus a status input from the alarm and a aux in from the alarm.
    If you don't have an alarm you can still gain auto up/auto down. The status out from the alarm if used will automatically roll up the windows when you arm the alarm. The 535T also has a vent feature if you do aux in for a split second it will roll them down a couple of inches. Or you can continue the pulse to roll down all the way.
    mechanicjon[QUOTED] likes this.
  20. Mar 9, 2017 at 2:53 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I LIKE IT!
