Remote Window Roll Up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RedManRocket, Mar 8, 2017.
  1. Mar 9, 2017 at 2:58 PM
    RedManRocket
    RedManRocket [OP] Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    If you figure it out let me know cause I have no clue what's going on :D
    loginfailed likes this.
  2. Mar 9, 2017 at 3:21 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So there are a couple different ways to go about hooking this up.
    1)You can intercept all of the window motor wires at the master switch in the driver door. (left front, right front, left rear and right rear) This will give only the driver seating position the one touch up/down feature for all windows, but still allow the other features in conjunction with the an alarm. (Roll up on arm, vent, roll down from aux channel). This is the least amount of work since you only have to run additional wires into one door. If you're usually the only person in the vehicle (or if you do frequently carry passengers, but don't care if they have one touch) then this is the best solution.
    2)You can intercept the window motor wires at each individual window motor. This will give each seating position the benefit of one touch up/down along with the other features in conjunction with an alarm. This is the cool way to do it, but is obviously more work, since you will have to run wiring into each door.
    cruiserguy and RedManRocket[OP] like this.
