Removable Doors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Aug 25, 2009.
  1. Aug 25, 2009 at 6:44 AM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  2. Aug 25, 2009 at 8:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    I have only seen one so far. I can't remember whose it was though.
    I want to do that to my '88.
    I say go for it!!
  3. Aug 25, 2009 at 5:05 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yea i think i will order them tonight
  4. Aug 25, 2009 at 5:07 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    :popcorn:
    I have to see how this one turns out...
  5. Aug 25, 2009 at 5:52 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    whats that suppose to mean..haha i just want to be able to stick my leg out the door while doing 80mph on the highway thats all...jk
  6. Aug 25, 2009 at 6:22 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i wont go wheeling with them off. thats why i am buying quick release hinges...i all need to do is find a connector that i can use to i dont have to worry about the wires. any one got any ideas on those
  7. Aug 25, 2009 at 6:27 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    ive thought about making them
    it'll be a hellova lot cheaper than buying the door hinges
  8. Aug 25, 2009 at 6:31 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yea but then i always have the options to go back to stock hinges
  9. Aug 25, 2009 at 6:36 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    well you can buy new hinges on ebay for ~14 bucks each and mod them
  10. Aug 25, 2009 at 6:39 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    what about speaker wires? i guess yalls windows arent auto, auto locks... if u had a couple of these options i would be difficult to be able to reinstall the door and have everything work, IMO
  11. Aug 25, 2009 at 6:40 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    yupp rite behing that kick pannel
    should be the plug with 2 wires going to it
    (unless your rich and have power windows, and power locks, ect)
  12. Aug 25, 2009 at 6:43 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    no i dont have power locks or windows or mirrors, i found this:
    "To get the old factory pin out without a fuss, cut it in half as it sits in the hinge, then take a cold chisel and start tapping around the edge of the top of the pin. (The hinges should be removed from teh vehicle first.) This should start to pry the pin upwards, then, when you clear the swege marks on the pin you can just pull it out. Repeat for the bottom half.
    If you manage to cut your hinges and then force out the stock pin without ing up the brash bushing, then you can use a 5/16 (.3125") dia. x 2" long grip length pin perfectly. The stock door hinge bushings are 8mm (0.315" dia). My passanger's door hinges worked out this way and it works awesome! This works so well I can hardly believe it. The pin is upside down on the top hinge because there isn't enough room to drop it down through the top due to the shape of the door's edge. A sharp eye will notice that the lower bolt head on the door's half of the hinge is ground down. This is so you can clear the pin's shoulder by the bolt. It had to be done to get a straight up shot for the pin. Also when doing it this way you can retain the factory brass bushing which will keep the door tight and have that OEM fell. My driver's door's brass bushings in both hinges cracked when we tried to pull the stock pin so we had to drill them out to 3/8" and use a 3/8" Pin or bolt with the head ground down. This eventually wears on the hinges and Ifinally ended up replacing them with some I could use a 5/16 pin in."
    taken form here: http://www.yotatech.com/f131/door-harness-quick-disconnect-127409/
    i am going to do the mod this weekend
    EDIT: i also found this: http://www.pirate4x4.com/forum/showthread.php?t=775832
    if i can find the right connectors i will do all this is weekend maybe a little write up
  13. Aug 25, 2009 at 6:49 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    sweet dude
    you should do a wrightup on how you did it and take plenty of pics when you do it
    oh and one more thing is it leagal to drive around with no doors???
    i kno i see jeeps do it all the time but is it legal for a truck to do it?
  14. Aug 25, 2009 at 6:55 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    those tube doors, while badass looking, seem pretty useless to me for a street rig. they wont keep anything out in terms of dust, water, or mud. why not buy half doors?
  15. Aug 25, 2009 at 7:00 PM
    pittim
    Pennsyltucky
    Boujee Prius
  16. Aug 25, 2009 at 7:15 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i dont want to do half doors, you might as well have no doors. i want to have the ability to put the stock doors back.
  17. Aug 25, 2009 at 7:39 PM
    pittim
    Pennsyltucky
    Boujee Prius
    right, im saying half doors instead of tube doors, since tube doors really only protect you from boulders coming in.
  18. Aug 26, 2009 at 5:41 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yea that would make sence but i would rather have no doors at all, and at 200 bucks i dont think i can find doors for anything around that price then i have to buy supplies to mod the door.
  19. Aug 26, 2009 at 5:57 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  20. Aug 26, 2009 at 3:11 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    so all you would need is the quick release door hinges, then you could take your doors on and off, right?
