Removable Fridge mount/slide options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WesLikesTacos, Mar 29, 2021.
  1. Mar 29, 2021 at 11:03 AM
    WesLikesTacos
    WesLikesTacos [OP] Well-Known Member
    21 Cement OR DCLB 4x4
    Let me know if I should repost this to another section of the site. I'd like to store my fridge in the bed, under my tonneau cover. I could just strap it down and slide it in and out but I'm thinking the more secure way is with some type of slide. However, I use my truck for more than camping so whatever method, I want to be able to be able to remove it when it's not in use relatively easily would be nice. It does currently fit in my backseat, which is ok but I'd really rather have it in the bed.
    So, has anyone come up with some type of system that is efficient to put in/remove for trips and secure? Even if you havent, ideas are welcomed. FWIW, I have bed stiffeners for added versatility/strap/bolt options.
  2. Mar 29, 2021 at 4:14 PM
    OldSkoolArcher
    OldSkoolArcher Well-Known Member
    Nick
    PA
    '24 Tacoma OR, '24 Defender 110, '15 WK2
    I just had the same dilemma the other day. After some brainstorming, I decided a good solution would be to purchase a header rail utility track from a 2nd Gen, cut it in half and bolt the two sections through the bottom of the bed and then attach the fridge slide to the tracks with t-nuts. When I want to remove the fridge and slide, I would remove fridge, loosen bolts that are in t-nuts and simply slide the slide out of the bed, leaving the track in place.
    This works in my head, but I haven’t installed it yet! Header rail just arrived.
  3. Mar 30, 2021 at 4:14 PM
    WesLikesTacos
    Keep me posted. Your idea sounds much more streamlined. Did you think about using the smaller unistrut?
    I'm thinking of utilizing my bed stiffener and side rail. Basically cut two pieces of ply and butt joint them at a 90. Then have a couple kick offs to the rail and a front "face" that'll bolt into the stiffener.
  4. Mar 31, 2021 at 11:56 AM
    OldSkoolArcher
    Nick
    PA
    I did think about unistrut, but had/have extra t-nuts and bolts laying around that I knew I could utilize in the Tacoma track.
  5. Mar 31, 2021 at 12:01 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The stock t-slot channel you plan to use is much thicker than the recess of the corrugated lines in the bed, so it's going to be sticking up above the highest point in the bed floor. Perfect to catch cargo on when "using the truck as a truck".
    Most people solve the problem by using L-Track instead. It sits lower than the high point of the floor so you won't constantly be catching things on it sliding cargo in and out of the bed.
    You could even just do tie down points instead of a longer rail.
    https://www.uscargocontrol.com/products/2-track-anchor-point-tie-down-kit-black
  6. Mar 31, 2021 at 12:02 PM
    JasonLee
    15 TRD OffRoad
    And for the header rail that just arrived, just remove the bolts that are already in the front of your bed and bolt it in. It's more useful there at the front of your bed than chopped up.
  7. Mar 31, 2021 at 2:04 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    I just leave the slide in all the time. Fridge gets strapped down to it when it use. Otherwise it sits in my dining room as a backup fridge, ha. The slide hasn't been a problem when I use my truck like a truck. The rack is more of an issue. But I have the tonneau brackets and a hoist in my garage so I can take it off when I need to. Just helped a buddy move a couch over the weekend with no problems.
    Lancejoker likes this.
  8. Apr 1, 2021 at 8:45 AM
    WesLikesTacos
    I like this idea.. holy moly is it expensive!!
  9. Nov 25, 2024 at 7:44 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Hi, how was the slide held up? Any damage to the bed from offroading?
  10. Nov 25, 2024 at 7:52 PM
    shaggy135
    Unfortunately I took that out a long time ago. Only because I got a bigger fridge. So I can't comment on any damage.
