Removal of paint on headlight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Muskwa, Aug 29, 2013.
  1. Aug 29, 2013 at 5:47 PM
    Muskwa
    Muskwa [OP] I don't roll on Saturday
    Carl
    In a van down by the river
    08 DC SB SR5 TRD OFF ROAD
    This is my dilema:
    I dripped some Duplicolor touch up paint on my headlight when I was touching up the hood.
    I took a shop towel and tried to wipe it off but I only made a big smudge.
    What can I use to remove the paint without f-ing up the headlight?
    Thanks guys.
  2. Aug 29, 2013 at 5:48 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Painter thinner?
  3. Aug 29, 2013 at 5:51 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Lowes sell's a product called lift off for removing excess paint, believe it's plastic safe. I'd avoid mineral spirits or paint thinner on plastic. I think the Lift Off stuff runs about $5 or $6 for a regular windex sized spray bottle.
  4. Aug 29, 2013 at 5:51 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    They use some stuff at the dealership to remove overspray..I can't remember what it's called. They got some overspray on my headlight and I told them to take it off and they did.
  5. Aug 29, 2013 at 5:53 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    Mineral spirits. Or you can do the spray and wipe fix. I usually get a can of carburator cleaner and spray to soak on a shop towel. Then I get a microfiber towel and soak it in a solution of dish soap and water. First I wipe with the shop towel then with soap towel right after to neutralize the chemicals before they eat on the clear coat or plastic of your lights.
  6. Aug 29, 2013 at 6:23 PM
    Muskwa
    Carl
    I wonder if a clay bar would work?
  7. Aug 29, 2013 at 6:24 PM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    Dont use paint thinner on plastic lights
  8. Aug 29, 2013 at 6:33 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    This. Most solvents will eat away plastic. I would try dish soap and elbow grease, a good degreaser maybe, or rubbing alcohol is usually safe on most plastics.
  9. Aug 29, 2013 at 6:35 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Get rubbing compound...and a micro fiber towel and it should come right off
  10. Aug 29, 2013 at 6:56 PM
    The Stig
    The Stig Well-Known Member
    I've used lacquer thinner on plenty of plastic things, lights included. As long as you're careful with it it should be fine. If you're worried test it in an area that's not noticeable.
  11. Aug 29, 2013 at 6:59 PM
    gjacobsjr
    gjacobsjr Well-Known Member
    Jerry
    Reno, NV
    12 Tacoma SR5 MagGrey on Black
    Black Raptor 16x8 Leer Shell Blacked out windows Pro Comp 3 in lift good year 265/75/16 Airaid CAI Cat Back 2 3/4 pipe with magnaflow and tip
    should be able to take a sponge to it with some simple green
  12. Aug 30, 2013 at 4:11 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    It also depends on what kind of plastic. Thinner does eat through plastics, if you only use a little bit and make sure you clean it all off quickly then it would be fine. I have melted plastic with thinner and acetone before haha.
  13. Sep 9, 2013 at 2:34 PM
    Muskwa
    Carl
    Well guys, I didn't use any paint thinners and went with a clay bar.
    The clay bar took the majority of it off and then I used Spray 9 with a bug sponge that took off the rest.
    I would suggest this method if this happens to you too.
  14. Sep 9, 2013 at 3:12 PM
    VinnyMack
    VinnyMack Well-Known Member
    Casey
    Buda, Tx
    07' PreRunner DC LB
    Brute Force Hybrid w/ custom Longhorn cutout, Satoshi w/ Hella 500's, Wet Okole's, Kenwood DDX419 CD/DVD Player, Fog Lamp Mod, BHLM, Blacked-out badges/grill/roof/valence, 5100's up front @ 1.75, 1.25" Spidertrax, TacomaWorld Sticker, extra D-Rings and custom bed mat, interior LED lighting, and Car Seat Mod.
    Easy- Simple Green
