REMOVAL OF PROCOMP 6" LIFT NEED HELP
Discussion in 'Suspension' started by IndianTaco, Mar 6, 2012.
  1. Mar 6, 2012 at 6:24 AM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    i have searched but cant seem to find the thread. in the next couple of months im gonna remove my procomp stage 2 lift. to install a 3 inch. but just not sure what it will take. i know i have to weld part of the cross member were it was cut but other than that im not sure. so if you guys and gals could please help me out that would be great
  2. Mar 6, 2012 at 7:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Shoot a PM to RuggedT. He is the most recent member to make this change, and should be able to help you out with questions you might have.
  3. Mar 6, 2012 at 7:28 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Replace spindles with factory ones. Remount diff. It's a project but more than doable on a weekend if you fabricate well
  4. Mar 6, 2012 at 5:25 PM
    IndianTaco
    thanks Guys all shoot RuggedT a pm
  5. Mar 6, 2012 at 5:29 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
  6. Mar 7, 2012 at 9:34 PM
    ironman44bear
    ironman44bear "Toyota Mafia" MORE BALLS THAN BRAINS
    Billy
    Clovis,CA
    05 DC Taco 4x4
    are you gonna sell the 6" lift....hmmmm:D
  7. Mar 8, 2012 at 5:19 AM
    315rider
    315rider Member
    will that lift fit a 05 tundra 4x4?
  8. Mar 9, 2012 at 7:39 PM
    IndianTaco
    not really sure but i highly doubt it
  9. Mar 9, 2012 at 7:43 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    im interested in the lift if itll fit my 2012 4x4
  10. Mar 9, 2012 at 7:48 PM
    RedDragonTaco
    RedDragonTaco Knight Industies Toyota Tacoma
    Slc, UT
    2007 Double Cab TRD Sport
    Toytec 3" Ultimate w/ LR UCA's, 18" Rockstar rims, Nitto Grappler 285/65/18, OEM roof rack, foglight anytime mod, front bull bar and Smitty side steps, tonneau cover, debadged, BHLM, blacked out tail lights, stubby antenna, flowmaster
    Were you not happy with the lift? Sounds like quite a project, good luck
  11. Mar 21, 2012 at 3:10 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    yup, I did mine.
    - reweld cross member
    - get factory spindles if you are 4wd. 2wd you can run aftermarks spindles, just not the procomp ones.
    - the diff does have to be remounted using the factory mounts (the front of the dif..they're 2 arm looking things). Now when I had 4 wheel parts install the lift, they only gave me one of the two mounts back. Who knows what they did with the other. I had to order a new one from toyota which I think came out to like $160..it was a very necessary mount.
  12. Mar 21, 2012 at 7:38 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    why not keep the lift? seems like a lot of work
  13. Mar 21, 2012 at 7:40 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    I'll never get to see the 6" lifted truck then Dave!? What is your reasoning for getting rid of it?
  14. Mar 27, 2012 at 8:21 PM
    IndianTaco
    Oh you'll get to see it Colton!! it's just a thought in the making
  15. Aug 31, 2016 at 5:53 PM
    Asowell90
    Asowell90 Member
    ANTHONY
    14 TACOMA TRD SUPERCHARGED 6" LIFT ON 35'S
    TRD SUPERCHARGER, 6" LIFT, FOX COILOVERS & REAR SHOCKS, CUSTOM WRAP, LEATHER INTERIOR, SOON TO HAVE AIR LOCKERS FRONT AND REAR :)
    I know its an old thread here but did you end up doing it? I want to remove mine and go mid travel 2" total chaos lowers and have a little more functional truck!
  16. Aug 31, 2016 at 6:14 PM
    YOTA 209
    YOTA 209 Instagram: Yota_209
    Stockton/Lodi CA
    2005 DCSB TRD off-road
    Lift - 887 OME/Bilstien 5100s LR UCA Dakar full leaf pack/Bilstien 5100s Tires - 285/70R 17 BFG KO2's Wheels - ProComp 5001's 17x8
    I just saw your post while doin research on what type of lift and wheel tire combo to do on mine. Please tell me how you liked your pro comp 6" lift with 33s.
  17. Aug 31, 2016 at 6:22 PM
    Asowell90
    Asowell90 Member
    ANTHONY
    Not sure if this was to someone else but I'll throw my 2 cents in, love the height and look of the 6" lift. I run 35's on mine and quite honestly without quite a bit of cutting and such they really dont fit. I am either going to 34's (which will still require some cutting) or going to take the whole lift out and go long travel....tough decisions
  18. Aug 31, 2016 at 6:31 PM
    YOTA 209
    Stockton/Lodi CA
    I'm leaning toward a 6 inch lift but have been talked out of running 35s by many saying I'd need to regear since I'd loose lots of power and Gas milage. What say you?
  19. Aug 31, 2016 at 6:38 PM
    Asowell90
    Asowell90 Member
    ANTHONY
    What gears do you have in yours now? My opinion will be scewed because of the supercharger, I have PLENTY of power and gas mileage with everything considered is about 13.
    YOTA 209 likes this.
  20. Aug 31, 2016 at 6:43 PM
    YOTA 209
    Stockton/Lodi CA
    Not sure. I'm just in a factory 2005 TRD V6
