Removal of Spots On Glass
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trooper440, Apr 5, 2010.
  1. Apr 5, 2010 at 9:41 PM
    Trooper440
    Trooper440 [OP] Active Member
    Scotty
    Alabama
    07 TRD Sport,Dbl. Cab, Short, Speedway Blue
    Bug Shield, Vent Visors, XM Radio, Black Toolbox, TRD emblems, N-Fab step bars, KMC XD 17"x9" wheels, Weathertech floor mats, Door seal protectors, Blue booster seat, 3" Ultimate lift, MT ATZ 285-70-17 tires
    Does anyone know of any product or technique that may remove the water spots that have - I guess stained my windows?
  2. Apr 5, 2010 at 9:45 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Sounds goofy, I had this out here in az as we have pretty hard water - a little polishing compound rubs em right out, and didn't screw up the windows.
  3. Apr 5, 2010 at 9:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    or some fine steel wool with water.
  4. Apr 5, 2010 at 9:48 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    vinegar and water
  5. Apr 5, 2010 at 9:59 PM
    Waking the Dead
    Waking the Dead Well-Known Member
    Raleigh, NC
    2010 TRD Sport DC LB Gray
    This stuff worked for me.
  6. Apr 5, 2010 at 10:15 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    razor blades from those box knives.
  7. Apr 5, 2010 at 11:13 PM
    MMOCGuy
    MMOCGuy Active Member
    Norm
    N. California
    09 Tacoma 4wd
    Bon-Ami. It is a cleanser that does not have bleach in it. It is available in markets in the same section where you can find Comet Cleanser with bleach.
    Bon-Ami used to be recommended by auto manufacturers and works great for removing road film, bugs and spots off of windows. just wet the window, sprinkle on the Bon-Ami (Or sprinkle it on a rag or paper towel_ and scrub the windows then rinse it off.
    Norm.
  8. Apr 5, 2010 at 11:20 PM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    Willows, CA
    06 AC TRD 4X4 SR5 6spd
    BHLM, Devil horns, trimmed front flaps, Flowmaster muffler,
    If you use steel wool, use the 000 grade, that way it wont mess up your glass. I have used CLR to some good results, just be sure to keep it off your paint. :)
  9. Apr 5, 2010 at 11:22 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Windex!
  10. Apr 5, 2010 at 11:59 PM
    pwrstrk02
    pwrstrk02 Well-Known Member
    randy
    kansas city missouri
    2010 4x4,dc,off road, black pearl
    vinegar and water. it will also take your wax off of your truck, so be carefull
  11. Apr 6, 2010 at 12:24 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    When someone wants to salvage an old window out of a classic car, they can wet sand the window, it cleans it up real nice.
    They use a fine grit of sandpaper/water, and work down in steps to a finer grit.
    But I probably wouldn't recommend trying this, I don't have the guts to try it.
    They sell polishing machines and compounds for car windshields, but that would be last resort if everything else fails. Try calling up some of your local auto body shops and see if they have the experience to wet sand, or have a polisher.
  12. Apr 6, 2010 at 12:42 AM
    FuzzyTaco
    FuzzyTaco Certified Smartass
    Utah
    07 Prerunner TRD OR
    Plain ol' Rubbing compound always worked wonders for me!
  13. Apr 6, 2010 at 1:00 AM
    Jap
    Jap Loving this
    TRD supercharger, extractors, 7 psi pulley, Interceptor ECU
    A really good window cleaner and some effort.
    I use Meguiars Glass Cleaner and it works very well.
  14. Apr 6, 2010 at 1:45 AM
    BWro
    BWro Well-Known Member
    Bon - Ami cleanser
  15. Apr 6, 2010 at 1:47 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Stoner's Invisible Glass and very little elbow grease always works for me. I have unfiltered Pinal county liquid calcium (aka what they pass for water here). Works for me every time.
    Note, if you have tint on your windows never use Windex or any ammonia based cleaner on the tint side... it will eat the adhesive and make it bubble up.
  16. Apr 6, 2010 at 1:57 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    x2
  17. Apr 6, 2010 at 2:14 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Op, I would suggest using steel wool like some of the other guys have said. The finest u can find. I think it's 000? Spray windex on your glass and rub the steel wool around and it will take everything off! Your glass will be squeeky clean. Oh and don't worry it won't scratch, I've done it to hundreds of cars. Some of wich were very expensive.
  18. Apr 6, 2010 at 6:38 AM
    Trooper440
    Scotty
    Alabama
    Thanks, I greatly appreciate the info.! I've got to get this stuff off my glass.
  19. Apr 6, 2010 at 6:44 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I use a few different things, Bar Keepers Friend to get all the crap off the windshield then invisible glass to clean it up.
  20. Apr 6, 2010 at 6:48 AM
    Fireguy67
    Fireguy67 Rebecca and Willow's Opa
    Klaus
    Maple Ridge, BC
    2013 4X4 4 door long bed TRD sport
    No mods- running boards, vent visors all around ,Leer XQ Cap, hood deflector,bed extender, OEM roof rack, Toyota bed mat.Nothing fancy!
    If all else fails or you're not happy with the other products mentioned try a "Mr. Clean Magic eraser" Damn think works phenomenally fro me on everything and does not scratch.
