****REMOVE**** 12-15 Retrofitted OEM Headlights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by david.e, May 17, 2020.
  1. May 17, 2020 at 7:09 PM
    david.e
    david.e [OP] Well-Known Member
    David
    Sacramento, CA
    08 X-Runner
    OEM Housings (no broken tabs) Frames painted Black Semi-Gloss
    Image976, wilson704, mx355 and 7 others like this.
  2. May 18, 2020 at 10:29 PM
    steve aleve
    steve aleve Member
    How do acmes compare to Morimoto?
  3. May 19, 2020 at 5:16 AM
    david.e
    David
    Sacramento, CA
    08 X-Runner
    from my experience working with the 2 the acme is a good kit for the price, but the morimoto is better. out the box you can see and feel the difference. most of the lights i have retrofitted had the acme kit due to the price.
    steve aleve[QUOTED] likes this.
  4. May 21, 2020 at 9:40 AM
    david.e
    David
    Sacramento, CA
    08 X-Runner
  5. May 21, 2020 at 7:54 PM
    wilson704
    wilson704 Well-Known Member
    Wilson
    2013 Tacoma
    love that chrome shroud wish i went that route. still love mine!
    david.e[QUOTED][OP] likes this.
  6. May 21, 2020 at 8:17 PM
    Tacoma_Wa253
    Tacoma_Wa253 Well-Known Member
    Sav
    Tacoma Washington
    07 Taco
  7. May 24, 2020 at 3:26 PM
    david.e
    David
    Sacramento, CA
    08 X-Runner
  8. May 26, 2020 at 2:54 PM
    david.e
    David
    Sacramento, CA
    08 X-Runner
    guess no one wants these. i'll take it down at the end of the week and put those parts to use and rebuild my M-LED set. here to help out TW members, if not win win for me.
    12TRDTacoma likes this.
  9. May 26, 2020 at 2:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you go M LED you will love it. I personally recommend that you epoxy or use some sort of permanent adhesive to run some metal headlight adjustment tabs inside there. The M LEDs are heavy so if you stick with the OE plastic adjusters you will be moving out of adjustment very often.
  10. May 26, 2020 at 3:03 PM
    david.e
    David
    Sacramento, CA
    08 X-Runner
    thanks, ive been building for a while. the M-LEDs were just coming out before i went overseas, over the time i heard so much hype about them and figured i try them out. i had them on the truck for a little bit but prefer the HIDs. M-LEDs had less wiring and were bright immediately when turned on, but i feel the HIDs still had a more wider spread and projection. i dont plan to sell my M-LED kit so i figured id redo them and do a true retrofit and keep them on hand when i get bored or if i need to upgrade my current set :thumbsup:
  11. May 28, 2020 at 7:21 PM
    david.e
    David
    Sacramento, CA
    08 X-Runner
    bump. these will be removed tomorrow
