Remove an AAL if installing a new lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MacMan123, May 25, 2020.
  1. May 25, 2020 at 2:16 PM
    MacMan123
    MacMan123 [OP] Member
    Colin
    Arizona
    2011 Black Tacoma TRD
    Bull Bar
    I already have a 3 inch lift up front and a 1.5 AAL in the back. If I decide to buy a 6 inch lift and it comes with a rear 4inch block, can you remove a single leaf to then install the block or do I have to buy new leafs? Thanks so much!
  2. May 25, 2020 at 2:35 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Are you sitting level now? If it were me, I would try a two inch block with the current spring set up you already have. Because it will come up... blocks have a draw back in a suspension. The spacing block acts as a leverage arm against the spring under acceleration and will create a situation call spring wrap. So a 4" block would have more leverage than a 2" block and make the spring wrap worse. Personally I wouldn't sweat a 2" block set and because the cost is so low you could give that a try- target would be to put new leafs in the rear. Locally I have spring shop, you could drive up and they could walk you through adding extra leafs to your pack or build you new set for a reasonable price.
