remove catalytic converter for performce
Discussion in 'Performance and Tuning' started by die2live, Nov 11, 2010.
  1. Feb 28, 2011 at 8:57 AM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    How in holy hell would removing any part of your exhust improve air into your engine ????????
  2. Feb 28, 2011 at 10:53 AM
    N3ZAT
    Charlie
    Coatesville,Pa.
    09 tacoma
    xpipe is the way to go mixes both banks so it sounds like a six cylinder instead of two three cylinders.
  3. Apr 18, 2011 at 5:01 PM
    dzlguy
    dzlguy Member
    McGee
    Decatur,AL
    Tacoma 4X4
    K&N airfilter,3 IN BodyLift, ARE camper shell yakima rack ,magna flow exhaust
    i just put a magnaflow cat on mine
  4. Apr 19, 2011 at 4:20 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    This thread is retarded. :drool:
    JMY24 likes this.
  5. Apr 19, 2011 at 4:27 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    In the Bay Area, people have their Cats removed in the middle of the night.
    Tacoma186 likes this.
  6. Aug 13, 2011 at 11:00 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    i just got a flowmaster delta flow put on mine and im not too happy with it
  7. Aug 21, 2011 at 8:12 PM
    azaware
    azaware New Member
    My cat was ripped off so I had a old cat so I broke the inside out and install it.:)
  8. Dec 23, 2013 at 6:33 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Other guys on another form said back pressure doesn't effect efi engines and the URD o2 simulator is for the back o2 sensor and it just tells the engine the cat is working correctly. The front one tells the engine the air/ fuel mix.
  9. Dec 23, 2013 at 6:37 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Removing the cat will gain you zero performance.
    Cats ofer very very little restriction these days, unless they're damaged.
  10. Dec 23, 2013 at 10:41 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    That's true. I was at the muffler shop today and got an opportunity to look inside my cat. It's just a really fine straight through grid. The cat is way larger in diameter than the pipe to account for the space that the grid takes up. After seeing that, I don't believe they offer any flow resistance at all.
  11. Jan 14, 2016 at 5:14 PM
    K80
    K80 New Member
    98 tacoma
    Have any of you that removed your cat checked to see if the cat was clogged up. My 3.4 doesn't have much power so I thought the cat might be clogged and restricting the exhaust.
  12. Jan 15, 2016 at 5:26 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    If you're not turbo/SC, the gain from removing cats is maybe minimal.
    Every accessories, bend, elbow, valves, name it, create a pressure loss (compare to a strait section of pipe) proportional to the flow speed.
    One thing i can say for sure, after changing my Y-pipe for a decated one, i had to change my fuel pump cause i was not able to maintain AFR. I was already SC with DTLT headers and 2.85 pulley.
  13. Jan 19, 2016 at 3:32 PM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    I dont really know much about this but I'm wanting to do something with my exhaust soon. if you downsized your pipe after the cats then throughout the system would that help in keeping the back pressure up enough to keep low end power?
  14. Jan 24, 2016 at 8:23 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    this. i have long tubes and a y pipe (OBX, a replica of doug thorley) and my low end sucks now. top end rips but im seriously debating on putting some shorty headers on (which i had on my previous tacoma) and it had much better pep and low end.
  15. Jan 25, 2016 at 12:01 AM
    #35
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    yup...... I threw on (in one day) long tubes......ypipe......3" catback..... total fooking mistake. I had the tq curve of a civic. I immediatley ordered the blower and got the tq back and then some
    steezinstangl[QUOTED] likes this.
  16. Jan 25, 2016 at 12:02 AM
    #36
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    altitude?
  17. Jan 25, 2016 at 5:37 AM
    #37
    Vassily28
    Attitude: good
    Altitude: 0-100 ft.
  18. Apr 24, 2018 at 9:55 PM
    #38
    nacgang
    nacgang Member
    Dylan
    Black Tacoma Lifted on 33s
    Lifted
    Can you send a video of your true duals with only 2 cats???
  19. Apr 25, 2018 at 12:46 AM
    #39
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    What he said. You are not going to see positive gains unless you have forced induction.
  20. Apr 26, 2018 at 9:00 AM
    #40
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    This is a thread that won't die.
