Remove catalytic converter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pleaser, Mar 21, 2017.
  1. Mar 21, 2017 at 4:40 PM
    Pleaser
    Pleaser [OP] Member
    Dea
    98 red Tacoma SR5 Xcab
    None
    Heard there is a way to trick computer into thinking its still there so check eng. light will go off???
  2. Mar 21, 2017 at 4:46 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Yes--click here--you will need a properly functioning rear O2 sensor.
    Not that this will not trick a tail-pipe sniffing emissions tester...
  3. Mar 21, 2017 at 5:06 PM
    Pleaser
    Pleaser [OP] Member
    Dea
    None
    Registering in northern AZ this summer, no emissions required
  4. Mar 21, 2017 at 5:26 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I've made a couple. They are easy as long as you realize the sensor wires are StainlessSteel and hard to heat. Use good flux.
    To tell the truth though an electrical guy told me butt connectors would work as good. Just might come loose.
    Pleaser[OP] likes this.
  5. Mar 21, 2017 at 5:30 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    :notsure: Doesn't URD make a simulator? Or am I way off?
  6. Mar 21, 2017 at 5:32 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    homemade is cheap.....real cheap.
  7. Mar 21, 2017 at 5:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you never have random inspections by the Hwy Patrol in AZ? Where they pull over vehicles, examine for things like light function, tire condition, and run a mirror underneath to see if the cat is still in place?
  8. Mar 21, 2017 at 5:49 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Seriously, Bill? Like you, I'm from a non emission state. Is this something that occurs regularly? This is something I know little about.
    Getting pulled over for no reason seems like a violation of a person's rights. A missing cat would not be a reason to be pulled over. How would LEO personal know there was no cat?
    DustStorm4x4 likes this.
  9. Mar 21, 2017 at 5:52 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    I have a trick to dump the raw sewage from my camper too!;)
    butsack and koditten like this.
  10. Mar 21, 2017 at 5:54 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    WHAT????? Oh hell no. 18 wheelers, yea. I guess if TX thinks there's a buck in it they will.
  11. Mar 21, 2017 at 5:57 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    You have to every so often. :boink:
  12. Mar 21, 2017 at 6:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    http://drivinglaws.aaa.com/tag/safety-inspection/
    Not just Fl. To check for cat presence, they just run a mirror on a stick under the vehicle.
    Ive 'heard' that creative types split, gut and fit an empty shell around the exhaust to visually deceive. Although I've never 'seen' such a thing. ;)
  13. Mar 21, 2017 at 6:09 PM
    Pleaser
    Pleaser [OP] Member
    Dea
    None
    I've been in AZ all my life and never had an officer look under my vehicle. Not that it couldn't happen. Anything is possible. As for the lack of a cat, my nephew tried to put a soldered inline resister to create a delta reading but didn't work, perhaps we will try again with hopefully the correct amount of resistance. Any suggested value?
  14. Mar 21, 2017 at 6:12 PM
    koditten
    Kirk
    Central Michigan
    I'm sure that happens.
    It seems like a lot of work for a daily driver vehicle.
    Hopefully, if I get pulled over, it was for a real reason.
  15. Mar 21, 2017 at 6:16 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    There's nothing really to be gained by removing it. But some people will tell you about removing them off their 1984 F-body and gaining Knight Rider speed.
    cruxofthebisquit likes this.
  16. Mar 21, 2017 at 6:20 PM
    koditten
    Kirk
    Central Michigan
    So, so true.
    Most don't realize this.
    Unfortunately the ones that do, removed theirs because they plugged the cat because they were too cheap or lazy to fix what caused the cat to plug.
    Once removed, the truck does run better because there is no plugged cat restrict the exhaust.
  17. Mar 21, 2017 at 6:54 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I have heard diff. vehicles or even diff same makes respond to varying resisters, look for rec'd for Toyo. I think it really just is supposed to match the capacitor. 1 mf, 1 ohm. or 5 mf, 5 ohm.
    Pleaser[QUOTED][OP] likes this.
  18. Mar 21, 2017 at 6:57 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Pull that camper on a hot TX day and there's a good chance of plugging up the cat, I melted one pulling a large boat.
    Basically, running at or near wide open throttle with a load down the hwy. can do it.
  19. Mar 22, 2017 at 9:20 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    Butt connectors work well, and as well as solder, IF you fill it with dielectric grease prior to inserting the wires, and use a staking type or better yet a full compression crimping tool.
    staking type:
    full compression type (finest kind):
    [​IMG] (shown), $12 w/a 20% off coupon, and often on sale for $10. I also have a 30+ year-old crimper made by Paladin Tools (now Greenlee). The HF tool crimps just as well, time will tell if it lasts 30 years...
