Remove driver side pillar trim
Discussion in '2nd Gen. Tacomas (2005-2015)' started by river rat 69, Mar 11, 2011.
  1. Mar 11, 2011 at 6:53 AM
    river rat 69
    river rat 69 [OP] Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Are there clips or is it jest a pop out.I did the small pry bar and pull but its not moving ?????? Thanks, Jim
  2. Mar 11, 2011 at 8:34 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
  3. Nov 19, 2015 at 5:12 PM
    DiamBag
    DiamBag Active Member
    Alex
    Utah
    2015 Magnetic Grey Access Cab, TRD Sport
    I'm having a similar issue, I can pop the clips out but the grab bars won't unscrew, I've almost stripped the head of one and now I'm stuck
  4. Nov 19, 2015 at 6:21 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I forget the size, but it is also a socket. I couldnt remove the screws with a screwdriver, but they came out easy with a socket set.
  5. Nov 19, 2015 at 8:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Use a socket and ratchet... I think it is a 10 mm
  6. Nov 19, 2015 at 8:09 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    sounds bout right
  7. Nov 20, 2015 at 7:34 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I pulled mine to install an Ultragauge, the bolt heads are 10mm.
    G.T. likes this.
  8. Nov 20, 2015 at 7:55 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Yup ^^ This ^^
    Pulled mine off to install the UG and dash cam
  9. Nov 20, 2015 at 5:01 PM
    DiamBag
    Alex
    Utah
    Hmmm that's really strange, I'm not home to look at it but I'm fairly positive they were standard doing screw heads.. Perhaps the old owner replaced them and that's when they were over tightened
  10. Nov 20, 2015 at 5:17 PM
    HawkShot99
    Kingston, NY
    They can be removed with a screw driver as well as with a socket. I first tried a screw driver, but it was to tight, so I used a socket and easy off.
    Justus likes this.
  11. Nov 20, 2015 at 5:37 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Not sure what a "standard doing screw head" is. Mine are a 10mm bolt head with a Phillips bit insert.
  12. Nov 20, 2015 at 6:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    if u wanna insert this guy "Phillip's" bit, that's ur call but I prefer to use a socket to remove the a pillar.
  13. Nov 21, 2015 at 7:00 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I don't like Phillip, not one bit. ;)
    Justus and spinglow like this.
  14. Nov 23, 2015 at 11:25 PM
    DiamBag
    Alex
    Utah
    Sorry I meant to say it's a standard rounded head screw, I cannot socket wrench it off
  15. Feb 13, 2016 at 4:28 PM
    1997tacomav6
    Denver
    I have the same problem, the screws are standard size, not a bolt, or screw and bolt, just a Philip screw.
    I think they are gluded in there maybe?
    I can't get mine to move one cm. I need the pillar off to install a boost gauge.
    Any other ideas?
  16. Feb 13, 2016 at 9:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The Toyota OEM is a 10 mm hex bolt with a phillips screw insert in the middle.
    If yours is different it has been replaced at some point with non-OEM item.
    If you are unable to move the phillips head screw, the best thing to do is stop before you damage the head of the screw.
    Get a manual impact wrench with a proper sized phillips bit and give it a few good raps with a hammer.
    McTeague likes this.
  17. Feb 14, 2016 at 6:30 AM
    1997tacomav6
    Denver
    I bought the truck new, so the screws are original, maybe in 1997 they were using just the screw design
    and later changed the design to the 10mm bolt with the screw, if I get them out I will change the them,
    I will try the impact then, thanks
  18. Feb 14, 2016 at 9:51 AM
    HawkShot99
    Kingston, NY
    You are posting in the 2nd gen forum asking these questions. People assume you have a 2nd gen.....
  19. Feb 14, 2016 at 9:53 AM
    1997tacomav6
    Denver
    Yup, I see that now, lol
  20. Feb 14, 2016 at 10:14 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    I never knew there was such a thing as a manual impact wrench, that's interesting!
