Remove epoxy'd bracket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lurkin, Nov 20, 2011.
  1. Nov 20, 2011 at 12:18 PM
    Lurkin
    Lurkin [OP] Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Anyone know what or how to remove a bracket that is epoxied to a window?
  2. Nov 20, 2011 at 3:25 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Rear slider, as in the linear actuator mod.
  3. Nov 21, 2011 at 3:32 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I am not sure if the rear glass is safety glass, may only be tempered without the laminated process.
    If it is solid, carefully warm it up with a hair dryer or heat gun. Depending on the epoxy it may work.
    I've done this many times with 5 minute epoxy on various materials. Better epoxy will require more heat.
    Be careful.
    PK
  4. Nov 21, 2011 at 6:13 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Problem with this is that the bracket is on the lower edge, right next to the plastic/rubber track. I'm thinking that heat will take the track out before the bracket. I'll have to look into if that window could be removed without too much trouble though. Thanks for the input.
  5. Nov 21, 2011 at 6:17 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You mad?! Don't be jealous :D
    Don't be, really! My linear actuator went belly up after only a year. Seems others have not had this problem. Cost to replace the LA went up, so I have decided to take a shot at BenWA's rear window mod (only a few bucks more and the window motor is much quieter then the LA. Problem is that the LA bracket is in the way. I can work around it, but wanted to see if I could remove it first.
