Remove Fender Flare & Fill Holes W/ Bondo?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by '14RC, Feb 19, 2020.
  1. Feb 19, 2020 at 10:39 AM
    '14RC
    '14RC [OP] WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    I want to remove my fender flares but I'm not a big fan of the 'plastic button' look when filling the holes with clips. Has anyone seen a write-up on getting smooth flares using filler?
  2. Feb 19, 2020 at 10:48 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Fiberglass the rear behind the holes and Bondo away. Or buy the fenders with no holes found on base models.
    TegoTaco, la0d0g, DG92071 and 2 others like this.
  3. Feb 19, 2020 at 10:55 AM
    '14RC
    '14RC [OP] WA State
    Seattle
    Oh that's a pretty good idea, so basically just some glass-cloth and epoxy to get it to stick to the inside of the fender?
  4. Feb 19, 2020 at 10:59 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Would it be different than filling any other hole with bondo?
  5. Feb 19, 2020 at 11:10 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Yep, clean the inside real well so the resin/epoxy adheres properly.
    Yes because it's a gigantic open hole. If you were to induce any vibration or huge pothole hits, they will definitely pop out of the holes which is why I recommend to have a backing to reinforce the Bondo.
    '14RC[QUOTED][OP] and Mully like this.
  6. Feb 19, 2020 at 11:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Assuming you are planning to refinish the body nicely, welding them up is an option too. By a skilled welder.
    mojojojo78 likes this.
  7. Feb 19, 2020 at 11:24 AM
    '14RC
    '14RC [OP] WA State
    Seattle
    Do you mean welding a plate on the backside of the hole and then filling the hole with weld instead of bondo? Suppose that could work as well! Maybe a bit more work for me personally since I don't weld but am pretty comfortable with using body filler.
  8. Feb 19, 2020 at 12:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    No, more like this
    https://www.youtube.com/watch?v=7S352if1HO8
    Lots of 'ads' for the Eastwood products/tools in the video, but you'll get the idea. Once the metal is worked, filler should just be a very light top coat
    '14RC[QUOTED][OP] and la0d0g like this.
  9. Feb 19, 2020 at 12:33 PM
    la0d0g
    running for the hills
    For crawling not hauling
    5 lug ebay fenders are $60. For me it's cheaper to swap them out.
  10. Feb 19, 2020 at 12:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I wish the bedsides were that cheap too
  11. Feb 19, 2020 at 12:39 PM
    la0d0g
    No doubt. Both mine are pushed in.
  12. Feb 19, 2020 at 12:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Same, mine look like wet cardboard. The lighting here really accentuates it.
  13. Feb 19, 2020 at 12:46 PM
    la0d0g
    Like but dislike. Yours are worse than mine :taco:
    EatSleepTacos[QUOTED] likes this.
  14. Feb 19, 2020 at 12:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yay, I winnn :bananadead:
  15. Feb 20, 2020 at 11:57 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  16. Feb 20, 2020 at 12:06 PM
    '14RC
    '14RC [OP] WA State
    Seattle
    hemitruk[QUOTED] likes this.
  17. Feb 20, 2020 at 12:49 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Don’t just mud them up. It’ll be a mess and it’ll never be right.
    Either weld or panel bond each hole individually. And body work that
    I’d cap each hole with some sort of plug until you can do it right.
    hemitruk likes this.
  18. Feb 20, 2020 at 1:25 PM
    '14RC
    '14RC [OP] WA State
    Seattle
    I think using glass mat w/ epoxy/resin would work fine if you're good with that medium, but it's a little messy. Panel bond seems less of a pain though.
  19. Feb 20, 2020 at 8:25 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    Your best bet is to get the fenders without the holes and use them. They will run you $60 to $80 and then paint them to match, which you would have to if you used bondo anyway. They will come out much cleaner and you could always sell the old fenders to be into it for almost nothing.
  20. Feb 20, 2020 at 8:47 PM
    '14RC
    '14RC [OP] WA State
    Seattle
    Yeah man I think that's the way to do it for the front but the rear fender/bedsides are another story ($$$)
