remove K&N heat shield?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovemytaco, Jan 23, 2010.
  1. Jan 23, 2010 at 1:24 PM
    ilovemytaco
    ilovemytaco [OP] Well-Known Member
    my intake has a light rattle sometimes so i was thinking of removing the heatshield to stop the rattle but i was wondering if thats bad? it might get more air but it would probably be hot..i dont know so im coming here for advice :)
  2. Jan 23, 2010 at 1:29 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    i had the same problem, u just need to move the filter farther from the heat sheild towards the passenger side of the car... and make sure everything is nice and tight
  3. Jan 23, 2010 at 4:46 PM
    ilovemytaco
    hmmm i tried it and it works but then it comes back...what do u think will happen if i remove the shield?
  4. Jan 23, 2010 at 4:49 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Nothing. It'll just take in hotter air causing a slight (Maybe barely noticeable) Decrease in performance.
  5. Jan 23, 2010 at 4:56 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    my cousin had the same problem but he fixed it just moving it further away
  6. Jan 23, 2010 at 6:20 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    If you remove the shield, what is your intake gonna sit on?
  7. Jan 23, 2010 at 6:33 PM
    Burgman
    Stephen
    Ric VA
    it doesnt sit on the heatshield
  8. Jan 23, 2010 at 7:03 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Then what does the "L" bracket below the intake connect to?
  9. Jan 23, 2010 at 7:05 PM
    Burgman
    Stephen
    Ric VA
    to the engine bay, the heat shield has a few spots where it connects to the engine bay and the filter floats through the hole in it... which is why most people get the rattle from it the plastic adapter on mine would bump against that L bracket but once i pulled it away it quit doing that for a while anyways
  10. Jan 23, 2010 at 7:19 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    I just installed mine two weeks ago. The heat shield bolts to the engine bay with two "L" brackets. Then the piping floats through the heat shield hole while being supported by the "L" bracket which is bolted to the heat shield.
  11. Jan 24, 2010 at 6:14 AM
    Burgman
    Stephen
    Ric VA
    what type of K&N do u have the black plastic or the metal one? b/c if it just rests on the L bracket then when your engine torques its gonna pull the filter away from the L bracket and then bring it back towards it causing a rattle.. im interested at this point, but when i first had the rattle i called K&N and they said pull the filter farther away from the engine
  12. Nov 29, 2011 at 11:04 AM
    xx99sublime89
    xx99sublime89 Member
    steve
    San Diego
    05 trd off road prerunner 6 speed
    k&n intake, billet grill, in dash navigation, component speakers, 4 channel amp, flowmaster exhaust, JBA headers
    Hey if you or anyone else would like to sell you heat shield please let me know I'd be all over it
