Remove lumbar support from TRD seat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by helidave, Sep 20, 2013.
  1. Sep 20, 2013 at 7:59 AM
    helidave
    helidave [OP] Well-Known Member
    phoenix
    '10 DCSB TRD Prerunner
    I just picked up a 2010 DCSB TRD and the front seat is killing my back. Even with the lumbar support cranked all the way in I can feel the pad jamming into my spine.
    Is it possible to take the seat apart and modify the lumbar support so that it retracts further into the seat?
    Does anyone have pics or diagrams of the seat internals?
    Do I have to do anything special to keep the side airbag from going off in my face, besides disconnecting the battery and unplugging it?
  2. Sep 20, 2013 at 8:33 AM
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    you might have a fautly one bud. I would definetely disconnect the side airbag if your messing around near it just in case.
  3. Sep 20, 2013 at 8:36 AM
    helidave
    phoenix
    actually i just went out and played with the seat, and it looks like it's the bar that goes across the bottom of the backrest, below the lumbar support, that's giving me issues.
    Same question though.. has anyone ever taken the seat apart and tried to modify that bar to move it into the backrest more?
  4. Sep 20, 2013 at 9:52 AM
    bueller
    bueller Well-Known Member
    AZ
    You would happen to be on mtbr would you? If so, I rode National with you and a few other guys last year.
    Sorry for the OT
  5. Sep 20, 2013 at 10:00 AM
    helidave
    phoenix
    yep, that was probly me
  6. Sep 20, 2013 at 10:29 AM
    bueller
    AZ
    Strange about your seat though. I can't feel that bar at all pushing with my hand.
  7. Jan 12, 2014 at 8:22 AM
    ehp
    ehp Member
    ED
    2014 Tucoma
    I had the same problem with my 2008.
    I have three cages in my back at L3-4-5 and now am fused. That bar hurt my back so bad I was not able to drive the truck.
    I had to have the seat modified by having a Styrofoam wedge made approx 1 inch thick that tapered to 1/4 inch. It fit in the flat part of the seat. It was installed by taking out the seat. Cutting a piece of 1/4 plywood and fitting that between the springs and foam seat bottom, then the styrofoam was slid between the bottom of the seat and the plywood.
    What it did was get me higher that the bar.
    This was easy because I did not have to take the seat cover off. Just remove the seat couple of clips,
    I just bought a 2014 may have to do the same thing again.
    good luck
