Remove oil from driveway?
Discussion in 'Off-Topic Discussion' started by AvsFanTRD, Jul 14, 2010.
  1. Jul 14, 2010 at 2:56 PM
    AvsFanTRD
    AvsFanTRD [OP] Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    In an attempt to change the transmission oil I managed to get a large portion on the driveway so now how do I remove the stain that the oil left behind? What have you all had success with on old and new driveway oil stains?
  2. Jul 14, 2010 at 2:59 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    paved/concrete driveway?
  3. Jul 14, 2010 at 3:02 PM
    DaCapt
    DaCapt Mad Fisherman
    Phil
    Reno, Nevada
    2013 Tacoma 4X4 SR5 DC
    Grease sweep.. you let it soak it up and keep sweeping it , over and over. Then use laundry powdered soap or liquid... sprinkle it on the oil spot, then wet it down and use a scrub brush to work it in real good. Rinse and do again if needed.
    Good luck!!
  4. Jul 14, 2010 at 3:08 PM
    acmair
    acmair Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    I've tried Muriatic acid, its not too bad, but if the rest of your driveway isn't super clean, it'll make the part you clean look too clean
  5. Jul 14, 2010 at 3:10 PM
    AvsFanTRD
    Brandon
    Wyoming
    yes
  6. Jul 14, 2010 at 3:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i usually use an oil soak like cat litter....then spray with brake cleaner and dawn dish soap.....comes up pretty well.
  7. Jul 14, 2010 at 3:27 PM
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
    x2
  8. Jul 14, 2010 at 3:50 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I've had success with Simple Green and DIsh Washing Soap. Let it soak about 5 minutes, then hit it with the hose. Hit it again and the stain is mostly gone.
  9. Jul 14, 2010 at 3:54 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Cat litter for starters. Pour it over and let it soak it up. After a while, move it around and even step on a 2" x 4" and drag it back and forth over the spot with your foot.
    You can always hit any left over stain with the caustic brew of choice suggested above for finishing touches.
  10. Jul 14, 2010 at 3:54 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I do Concrete coating and we use a mixture of TSB (Can be bought at Ace Hardware) its a white powder and mix it with xylone (Paint thiner also buy it at Ace) mix the two in a cup until its like a paste them put it on the oil spot and rub it in a little and leave it overnight. Next day hose it off. It should do the trick :)
    Note wear gloves doing this. it will burn you if you dont.
  11. Jul 14, 2010 at 3:57 PM
    CO_Steve
    CO_Steve Active Member
    Monument,CO
    11 SR5
    Castrol Super Clean straight up. Good for cleaning lots of other greasy stuff too, although usually need to dilute.
  12. Jul 14, 2010 at 4:01 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Try pouring a can of Coke (non-diet) on the oil stain. Leave it for 2 to 3 hours, then rinse thoroughly with a hose. Next sprinkle powdered Tide over stain and leave overnite. Rinse completely the next day The stain should be history.
  13. Jul 14, 2010 at 4:05 PM
    scocar
    scocar hypotenoper
    I've had good luck with Simple Green on minor spills on my pretty old, porous concrete driveway. Spray it on, scrub it with a stiff brush.
    I would avoid using most all the other heavy duty industrial/petro-based solvent stuff mentioned in other posts, because when yo uwash it off, if is going into your groundwater and creeks. Not good for you or your community or the critters. Ask BP.
  14. Jul 14, 2010 at 4:07 PM
    JAG
    JAG Well-Known Member
    Gasoline.... no joke. Just don't smoke around the area. Soak drive with water after your done. And don't let anyone see you pour gasoline out.
    FLAME AWAY
  15. Jul 14, 2010 at 5:21 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I think he was asking concrete vs blacktop.
  16. Jul 14, 2010 at 9:24 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    Purple power!!! stuff works great on my black top driveway. ive even used it in my garage and it works great
  17. Jul 14, 2010 at 10:00 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2, this is what I do and it works great.
  18. Jul 20, 2010 at 11:24 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I've used a product sold at Auto Zone that is an orange powder and safe for the environment wont kill your bushes or grass.........have had pretty good luck with it.........I will see if I can find the name of the product.........
  19. Jul 20, 2010 at 11:52 AM
    396tears
    396tears Well-Known Member
    x2
    works well for me
    you might need to brush or do it more than 1 time
    depending on how soaked in it is
  20. Jul 20, 2010 at 11:54 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    power washer
