Remove one leaf to lower rear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VA Tacoma, Jul 7, 2016.
  1. Jul 7, 2016 at 12:53 PM
    VA Tacoma
    VA Tacoma [OP] Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    My brother wants to lower the rear of his 06 to level it. Any experience, good or bad, from doing this? He isn't concerned about payload, only how much one leaf might lower it.
    Thanks
  2. Jul 7, 2016 at 1:11 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Well, when I was looking at add-a-leaf's yesterday to lift my truck with, the company I was ordering from stated that a one leaf AAL (on both sides obviously) would raise the rear about 2", so taking one off would lower it by that much I would assume :notsure:
    How much higher is the back end sitting than the front? May just be easier to put in small spacer plates in the front to bring it level with the rear if it isn't that much of a difference.
  3. Jul 7, 2016 at 3:56 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Do you know how many leafs are in the pack now? if it has the over load that gets you about .5". If you were to remove a spring I would guess 1.5 to 2" based on playing with other projects. Leaf packs are not complicated if you dont like it, easy to put back.
  4. Jul 7, 2016 at 4:14 PM
    Pigpen
    Dan
    Northwest Montana
    Just put in a longer shackle. You'll lower the truck almost exactly the extra length of the new shackle.
    Blkvoodoo likes this.
  5. Jul 7, 2016 at 4:28 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What leafs does it have in the rear? If it is the stock 2+overload I would not remove a leaf. Those springs are notorious for breaking already.
  6. Jul 7, 2016 at 4:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Raise the front
    Kyitty likes this.
  7. Jul 7, 2016 at 4:37 PM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Thanks, guys
  8. Jul 7, 2016 at 4:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah raise the front, or use a longer shackle in the rear.... the stock springs are already shitty enough... dont pull leafs out.
  9. Jul 7, 2016 at 9:04 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    If he has factory/original rear leaf springs the last thing you want to do is make them weaker by removing a leaf. The factory rear leaf springs on Tacomas are horrible and notorious for sagging over time anyhow.
    Norton likes this.
  10. Jul 8, 2016 at 12:59 PM
    tgear.shead
    tgear.shead Well-Known Member
    I keep hearing this, and applied to both the 3-leaf US version, and the 4-leaf CAN version. Frankly, it takes WAY more than the payload capacity to get this thing sitting on the bump stops, and after several years now, my all original 4-leaf is still sitting nice and tall in the back. I wonder if they could have had different suppliers?
  11. Jul 8, 2016 at 1:08 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Canadian 4 leaf? As in 4 leafs plus overload?
    The truck should never sit on the bump stops, even fully loaded the truck still needs to have usable suspension travel.
  12. Jul 8, 2016 at 1:11 PM
    OZ-T
    Peter North
    British Columbia
    The old US packs were 2 leaf + the overload , the Canadian trucks all came stock with the 3 leaf + the overload that later became the US "TSB" pack
  13. Jul 8, 2016 at 1:11 PM
    tgear.shead
    As in TOTAL of 4. Unlike the USA config which had TOTAL of 3 until more recent models.
    Like I said, it doesn't sit on the bump stops fully loaded. It has to be WAY over, as in over a full TON, which I have had on it.
  14. Jul 8, 2016 at 1:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yeah, that is what I thought but just clarifying as my 2015 has 3+overload and I think the springs are way to soft in stock form.
  15. Jul 8, 2016 at 1:15 PM
    OZ-T
    Peter North
    British Columbia
    The stock leafs suck
    Norton likes this.
  16. Jul 8, 2016 at 1:19 PM
    tgear.shead
    That's why I'm wondering if there were multiple suppliers. My experience with the FACTORY springs (I got this thing brand new from the dealer) is inconsistent with above points of view.
  17. Jul 9, 2016 at 5:22 AM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    Who makes longer shackles ?
