Remove plastic from rear bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AvsFanTRD, May 18, 2010.
  1. May 18, 2010 at 3:36 PM
    AvsFanTRD
    AvsFanTRD [OP] Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    How the hell do I remove the plastic off the rear bumper? I have been fighting with it for hours and I've gotten no where. What am I missing?
  2. May 18, 2010 at 3:45 PM
    ACE_Taco
    ACE_Taco Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    You talking about the bumper step cover?
    Crawl under the truck with a flashlight and look up where the step mouts. You will see a bunch of plastic tabs that are penetrating the bumper cover. Start at one end and squeeze/push upward on a few. This will get it started where you can get your fingers under the step cover from above. Then, carefully pull it off working your way to the other side of the truck. Do a section at a time and take your time. The tabs are a little flexible, but not bullet proof.
    On the corner pieces of plastic there are three nuts and bolts that secure those. Two of the bolts are mounted in the plastic. I removed the bumper cover to access those and dismantle.
    HTH
  3. May 18, 2010 at 8:26 PM
    AvsFanTRD
    Brandon
    Wyoming
    Thankfully I have the bumper off already so less crawling.
    the plastic tabs near where the license plate go is what is part of the trouble. they are like plastic screws that when turning, nothing happens.
    The corner pieces are also kicking my ass. I turn the nut but the bolt turns with it.
  4. May 18, 2010 at 8:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    why did u take it off?
  5. May 18, 2010 at 8:52 PM
    AvsFanTRD
    Brandon
    Wyoming
    the original was ruined and had to get a new one so i haven't put it on yet. was planning on putting bed liner on the new one since it's not chrome like the original
  6. May 18, 2010 at 9:00 PM
    ktmrider
    Junk
  7. May 19, 2010 at 6:43 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The plastic tabs are actually push pins, not plastic screws.
    On the corner pieces I had the same problem as it appears that they are lock-tite'd from the factory. I had to grab the end of the bolt with channel locks (the bolt is tapered, so the threads aren't permanently messed up as long as you grab just the end), then turn the nut. That bolt has a square head that is in a slot in the plastic, with the lock-tite it just turns in the slot.
  8. May 19, 2010 at 9:28 AM
    AvsFanTRD
    Brandon
    Wyoming
    Oh, ok I'll give that a try. Just need to get myself some channel locks.
  9. May 19, 2010 at 9:33 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    My bumper was chrome, but I removed it and used Duplicolor Bed liner. I took the cover off. It is very easy and only takes one person. About 10-12 bolts.
  10. May 19, 2010 at 10:48 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ...or pliers, vice grips, teeth...
  11. May 19, 2010 at 1:52 PM
    AvsFanTRD
    Brandon
    Wyoming
    I went with vice grips and it worked great. Finally got all the plastic off!
    Now the sanding process begins!
  12. May 19, 2010 at 2:10 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Those corner ones were a PITA! I struggled there as well, when I put mine back on I through some gorilla glue in there to keep it in place. Has held up great
  13. Mar 14, 2011 at 1:21 PM
    JTO
    JTO Well-Known Member
    San Diego
    PreRunner Sport
    does anyone know were i can order the bolts for the corner pieces? I had taken one off a while back with the intention of putting it back on later and now i cant find it.
  14. Mar 15, 2011 at 6:58 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Have you checked a hardware store for a flat, squared headed bolt? I've seen them at Lowes/HD I think. If the flat head is too big, might need some trimming, but good excuse to break out/acquire a Dremel.
