Remove Plastic in Front of Windshield
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrh95, Jan 2, 2013.
  1. Jan 2, 2013 at 3:17 PM
    jrh95
    jrh95 [OP] Member
    Pensacola, FL
    02 PreRunner V6 SR5
    Westin Safari Light Bar, KC Daylighters, Alpine Head Unit and Speakers, LED Light System in the Bed, Pioneer 12in Sub
    Does anyone know how to remove the slotted black piece of plastic that's in between the hood and windshield? It's the piece with the wipers coming out of it. I want to remove it so I can paint it since mine is really faded. My only concern is how to take it off so it can easily be put back on and I also have no clue how to completely remove the windshield wipers and that seems necessary to remove this plastic piece. Any help is appreciated.
    GQ7227 likes this.
  2. Jan 2, 2013 at 4:51 PM
    Madjik_Man
    Colorado Front Range
    It's called a cowl (just fyi in case you want to google search)
    Remove the little caps at the base of the wipers. One bolt holds each wiper on. Then, if it's anything like my 98 it's just a couple screws and a few plastic clips to remove the cowl.
  3. Jan 2, 2013 at 6:02 PM
    jrh95
    jrh95 [OP] Member
    Pensacola, FL
    02 PreRunner V6 SR5
    Thanks. I'll probably Google it but I had no clue what the name for it was. I saw the screws to remove the cowl but removing the wipers was the only complication I saw. Thanks a lot once again!
  4. Mar 8, 2013 at 10:08 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Just did this today. There's one 14mm bolt for each windshield wiper, unscrew those and pull the wipers off. After that unscrew the 6 screws that are holding that cowl in. Then pop the hood and take out the 4 plastic pieces (screws) holding in the weather stripping. Once all this is done then wiggle the cowl on out and there you have it
    Wulf and ThunderOne like this.
  5. Mar 9, 2013 at 7:13 PM
    jrh95
    jrh95 [OP] Member
    Pensacola, FL
    02 PreRunner V6 SR5
    So far it seems like it would be pretty easy to do. Hopefully when Spring Break rolls around I'll have time to work on it. It really needs to be painted because taking my truck through some pretty nice mudholes has stained the cowl a lighter, dirty color and no "back to black" product seems to have done any good. Thanks for the input.
  6. Mar 10, 2013 at 9:40 AM
    Madjik_Man
    That's UV oxidation of the plastic.
    See my before and after pictures:
    GQ7227 likes this.
  7. Mar 11, 2013 at 9:56 AM
    yote
    Mark
    Tacoma, WA
    Looks 100x better!
  8. Mar 16, 2019 at 6:06 PM
    Melvin 01 Tacoma guy
    Melvin 01 Tacoma guy New Member
    2001 Toyota Tacoma
    Jrh95 what was it you used to bring that out from the oxidation?
    GQ7227 likes this.
