Remove Readylift????
Discussion in 'Suspension' started by chris2011, Dec 11, 2011.
  1. Dec 11, 2011 at 6:21 PM
    chris2011
    chris2011 [OP] Active Member
    CHRIS
    Hudson,NC
    2015 Double Cab 4x4 v6
    I have readylift kit on 2011 access cab 4x4 with blocks in back. Changed rear shocks and had some rough country shocks put on. Now, im wanting to take readylift kit off and go back to factory. How best way to take spacers off??
  2. Dec 11, 2011 at 6:23 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Reverse of the way you put it on
  3. Dec 11, 2011 at 6:23 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Is it a top plate spacer or a coil spacer?
    Either way you'll have to remove the coilover assembly from the truck. If its a coil spacer you'll also need a spring compressor.
  4. Dec 11, 2011 at 6:25 PM
    chris2011
    CHRIS
    Hudson,NC
    I had a shop to put it on and money a lil tight here at holidays and was going to do it myself.
  5. Dec 11, 2011 at 6:26 PM
    NC15TRD
    Nick
    PA
    Readylift is all top plates on tacomas
  6. Dec 11, 2011 at 6:26 PM
    KPT
    09 Prerunner
    Gotcha. Well that will make it easier.
  7. Dec 11, 2011 at 6:32 PM
    NC15TRD
    Nick
    PA
  8. Dec 11, 2011 at 6:32 PM
    chris2011
    CHRIS
    Hudson,NC
    Once strut assembly is out will i need a spring compressor to take spacer off???
  9. Dec 11, 2011 at 6:33 PM
    KPT
    09 Prerunner
    You will not.
  10. Dec 11, 2011 at 6:37 PM
    NC15TRD
    Nick
    PA
    Simply unbolt spacer and reinstall strut
  11. Dec 11, 2011 at 6:37 PM
    chris2011
    CHRIS
    Hudson,NC
    Ok thanks! So once spacer is off just put strut assembly back on to get factory ride height??? Thanks for help!!!!!
  12. Dec 11, 2011 at 6:38 PM
    KPT
    09 Prerunner
    Get an alignment right afterwards.
  13. Dec 11, 2011 at 6:39 PM
    NC15TRD
    Nick
    PA
    You got it
  14. Dec 11, 2011 at 6:39 PM
    chris2011
    CHRIS
    Hudson,NC
    Yeah most definately. Thanks alot for help man!!
  15. Dec 11, 2011 at 6:42 PM
    KPT
    09 Prerunner
    No problem
    :gossip: Thank Nick too
