Remove spare tire to save weight, plus some 4wd questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DavisBladeWorks, Sep 19, 2013.
  1. Sep 19, 2013 at 3:12 PM
    DavisBladeWorks
    DavisBladeWorks [OP] Well-Known Member
    North ATL
    2013 DSCB TRD Sport 4x4
    Ah ok, thanks. :)
  2. Sep 19, 2013 at 3:13 PM
    DavisBladeWorks
    North ATL
    I'll just leave the spare.
    I'd rather not pull the secondary air filter. I rather like not having a direct dust injection intake.
  3. Sep 19, 2013 at 3:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, It is not illegal to be irresponsible ...
  4. Sep 19, 2013 at 3:41 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Yet you bought one that you traded in for some reason? Now you complain that the performance isn't up to the pre-runner you owned?
  5. Sep 19, 2013 at 3:43 PM
    worthywads
    Secondary air filter is to trap emissions and does not help trap dust.
    But it won't help performance either so leave it in for that reason.
    Good plan to leave the spare, it is there for an awesome reason.
  6. Sep 19, 2013 at 4:33 PM
    Fatalwishes
    Fatalwishes Member
    Fort Worth
    2011 Dodge Ram Sport CC 4x4
    This thread is lulz
  7. Sep 19, 2013 at 4:36 PM
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    But that will add weight???? :D
  8. Sep 19, 2013 at 4:52 PM
    kingofthecrate
    kingofthecrate Well-Known Member
    NELA
    2014 DCSB 4BYE IN YOUR MOUTH
    Keep the windows rolled up and lean forward when you drive.. it will add at least 3hp. Listening to lil wayne will increase wind drag as well
  9. Sep 19, 2013 at 5:13 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I always heard vehicles were faster without the driver.
  10. Sep 19, 2013 at 6:40 PM
    DavisBladeWorks
    North ATL
    The first question I can't understand therefore cannot answer. I bought one that I traded in? What does that mean.
    To the second question, I'm not complaining - I'm making an observation and trying to rectify the very real fact that the 4wd trucks are not as quick as the 2wd. Not sure why you're getting your panties in a bunch.
    I wanted 4wd, regardless of it being slower. I still do want it to be quicker. Not sure how or why that's hard for you to understand.
  11. Sep 19, 2013 at 6:43 PM
    DavisBladeWorks
    North ATL
    I am in the near future hopefully. I understand of course that a 4wd truck isn't a race car, but I'd still like more power. I think the supercharger would be the perfect fix. Wonder how much it is with installation?
  12. Sep 19, 2013 at 6:49 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
  13. Sep 19, 2013 at 6:55 PM
    169.254.255.201
    Interwebs
    Don't drag racers start out in 4wheel drive?
  14. Sep 19, 2013 at 6:58 PM
    DavisBladeWorks
    North ATL
  15. Sep 19, 2013 at 7:01 PM
    #35
    DavisBladeWorks
    North ATL
    You're being pedantic, you know what I meant.
  16. Sep 19, 2013 at 7:06 PM
    #36
    JdevTac
    Josh
    MD/GA
    2nd gen
    Last I saw, bulldog hadn't tested the tuner for a straight 4.0L, only supercharged Tacos. I haven't kept up with it though.
  17. Sep 19, 2013 at 7:09 PM
    #37
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    It's easy just press the gas pedal down more.
  18. Sep 19, 2013 at 7:15 PM
    #38
    JdevTac
    Josh
    MD/GA
    2nd gen
    Lol I usually give it a good slurp of gas off every green light, so I don't even notice any sluggishness.
  19. Sep 19, 2013 at 7:32 PM
    #39
    worthywads
    You are the one that bought a 2wd only days ago when I presume you thought that a truck didn't need to be 4wd, only to change your mind and trade it in for a 4wd after some sudden change in view, and stance that only 4wd for you.
    I don't understand any of that. You mistake me poking fun and humored by your illogical, as a panties in a bunch. :facepalm:
    Removing the spare is a hilariously stupid solution.
  20. Sep 19, 2013 at 8:11 PM
    #40
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    this is going well.
    op, congrats on your 4wd purchase. in terms of weight vs speed, a common rule of thumb is 100lbs per 1/10sec. of quarter mile time. spare doesn't even weigh that.
    im curious as to how 4wd would really effect perceived acceleration. I would guess maybe 250lbs additional, which in the grand scheme of things isn't much. maybe your new motor is still breaking in, adjusting to your habits, etc.
    there is a bit more friction from the c/v axles spinning, but not much. you can raise the truck and turn a front wheel very easily on mine.
    give it some time, it will work itself out.
    and your question on what to know about 4wd from a completely new standpoint:
    using it on dry pavement is harsh on it if you turn.
    using it in snow or loose gravel can get you in trouble at high speed. for the same reasons that it is not good to use on dry pavement, it will occasionally hurt you in high-speed turns on low-traction surfaces. it will take you far, but slower is always safer (regardless of drivetrain). there is a reason that racecars don't use 4wd.
    it is good to "exercise" the system. try and engage/ disengage once a month. Toyota suggests using it 10miles per month, but that doesn't jive with the dry pavement rule for most of us.
    keep an eye on the front axle boots. if you notice grease slung in your wheel well, one broke.
    the transfer-case and front differential are new to you. aside from exercising the actuators when you can, they contain gear oil that should be changed occasionally. I change every 30k miles, but I never had a factory maintenance schedule to tell me when. your manual will specify oil grade and weight. do your rear diff at same time. and if you are a manual transmission, do that too.
    that's about all I can think of for now. just remember that 4wd is not the perfect traction solution. it helps, but use caution just as you would with a 2wd on slick surfaces
