Remove spilled paint from my hood?
Discussion in 'Detailing' started by tcBob, Jun 14, 2012.
  1. Jun 14, 2012 at 9:37 AM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    a small amount of white paint got on my black hood...what's the best way to cleanly remove it?
  2. Jun 14, 2012 at 9:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What kind of paint, just plain old latex interior type paint or overspray from some other application?
  3. Jun 14, 2012 at 9:47 AM
    tcBob
    Bob
    yeah regular interior paint
  4. Jun 14, 2012 at 10:05 AM
    Pugga
    Massachusetts
    I'm not a detailer and, since you have a black truck, I'd wait for one to chime in because stuff will show up on your black paint that won't show on other colors.
    If it's a fine mist across the hood, I'd use claybar (or for interior latex, a plain wash might do the trick).
    Assuming the wash doesn't work, if it's a few drops, I'd go with a soft rag with some acetone (just enough to do the job, not a dripping wet rag).
    If you use acetone, I'd try it on the inside of a fender flare first, just to make sure what you're using won't mess with the paint. I've used it on mine before and it didn't do anything but I have a white truck. You'd also have to re-wax because the acetone will strip the wax from your truck.
  5. Jun 14, 2012 at 10:07 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Water based or oil based?
  6. Jun 14, 2012 at 10:07 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    gasoline........put it on a rag wipe(dont scrub) it off, then apply a good sealant or wax.
  7. Jun 14, 2012 at 10:09 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    i have the perfect stuff. . . cant remember the name. :eek:
    will look for it at work today. . we had a crew spraying some silver rustoleom paint on some metal structures at work one day and the wind carried off a bunch of specs and it got on a lot of employees cars, like 20 of them. we were afraid we'd have to pay to have all of them repainted. got this stuff from a detail shop that gets it off without damaging the clear coat. maybe someone could help me out, i know it comes in a metal can, bout a gallon and the brand starts with and "E". . .it's killing me right now not being able to remember, but i'll try and find a can at work when i go back in a minute.
    but anyway, we would just put some on a shop rag, wipe the cars down, and then pressure wash from a little distance away. cars looked like it never happened.
  8. Jun 14, 2012 at 10:10 AM
    Pugga
    Massachusetts
    x2, that works pretty well with removing interior paint.
  9. Jun 14, 2012 at 10:19 AM
    tcBob
    Bob
    water based
    i'll try acetone first, then gasoline if that doesn't work. thanks for the suggestions guys
  10. Jun 14, 2012 at 10:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Water based will come off with water...and it won't damage the paint.
  11. Jun 14, 2012 at 10:26 AM
    TacoFMS
    Justin
    Louisa County, VA
    yeah if its water based just use water and a good quality microfiber towel to scrub it off.
  12. Jun 14, 2012 at 10:27 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this....
    and if water doesn't do it try WD-40. Just wash it off after you use it.
    On the can of WD-40 it's got written on it that it takes bugs and tar off and it does a fine job at it, but with any petrol based product wash it off before it eats the paint.
    I would stay away from harsh chemicals that the others have said.
  13. Jun 14, 2012 at 10:29 AM
    XXXX
    sKiP
    05 Prius
    So you haz black hood...hmmm adding up all the clues and one day Ill find out what small island you live on and run the world from. :spy:
  14. Jun 14, 2012 at 10:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Actually the whole truck is black. You can see it in his gallery... :thumbsup:
  15. Jun 14, 2012 at 10:41 AM
    TacoFMS
    Justin
    Louisa County, VA
    well it was all black............
  16. Jun 14, 2012 at 10:41 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Dont use gas on Latex paint.. IT WILL MELT THE PAINT, use good ole soap and water..If that does not work use some OPPS or GOOF OFF..
  17. Jun 14, 2012 at 10:45 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    X3 - used this method before on spray paint over spray and Plasti -dip
    And followed up with Turtle wax black Box
  18. Jun 14, 2012 at 10:46 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    All these ideas are great. Getting paint off of paint without hurting your paint is tough. If its water based, then soak it with water for as long as possible. Then get a towel, a plastic scraped, gasoline, rubbing alchohol, and some drinking alchohol as well. Try getting at it with the plastic scraper first, then try the rest. Good luck
  19. Jun 14, 2012 at 10:48 AM
    Pugga
    Massachusetts
    I wouldn't use a plastic scrapper...
  20. Jun 14, 2012 at 10:52 AM
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    Gasoline isn't a harsh chemical, on car paint. You can use it as long as you wash it and put a coat of wax on the spot that you cleaned it with. I have done this a numerous amount of times on my own vehicles and on my customers vehicles. I explain to my customers that it WILL need to be waxed if I do it though because it strips the wax off. Everytime I have used it on a customers vehicle they are always calling back and wanting me to clean their cars for them. I don't have to tell them what "chemical" it is either. All I said was it's a "special and expensive chemical" that does the trick if nothing else will work. I of course use it as my last resort though if a claybar doesn't work.
    Gasoline won't hurt to use AS LONG AS YOU WASH AND WAX THE SPOT YOU CLEANED WITH IT!!!!
