Remove starter 4x4 truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoAlaMode, Nov 5, 2017.
  1. Nov 5, 2017 at 5:56 PM
    TacoAlaMode
    TacoAlaMode [OP] Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
  2. Nov 5, 2017 at 7:15 PM
    Muddinfun
    Muddinfun Well-Known Member
  3. Nov 5, 2017 at 8:20 PM
    TacoAlaMode
    Brian
    Huntsville AL
    I ended up separating the motor from the mount/solenoid. Was finally able to wiggle it out over the top of the LCA, driveshaft and catalytic. I’ll look into his method putting it back in. What a pain. Going to use the link you posted for cleaning it up and rebuild.
    Muddinfun likes this.
  4. Aug 14, 2019 at 11:07 PM
    Keone777
    Keone777 New Member
    Jesse
    2006 Tacoma SR5 4x4 V6 Crew Cab Long Bed
    Stock and running
    Was able to do it like you said, by detaching the front driveshaft and bringing it down that way. I brought it down back end first with the pinion gear pointing upwards. Just ended up that way after trying to go down by CV shaft and then turning around before taking off the front drive shaft.
    Easy peasy this way.
    I took off the steering shaft at the coupler, but not sure if that was necessary either. Guess it made getting my hand in there easier.
    Didn't loose hard brake line mount on frame either. That wasn't needed.
