Remove transmission fill plug, hot or cold trans?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Apr 9, 2024.
  1. Apr 9, 2024 at 2:24 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    Just thinking, that transmission case is aluminum and the plug is steel, would it be safest for the threads to remove it cold?
    Just curious if people usually remove the plug (break it free after a year or more) warm or cold.
    I know spark plugs in aluminum heads should be removed and installed in a cold engine.
    Thanks.
  2. Apr 9, 2024 at 2:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Manual transmission, I assume? I don't think it matters, I've done it both hot and cold. Just don't over torque it when reinstalling.
  3. Apr 9, 2024 at 2:38 PM
    tomrad
    No, automatic.
    Thanks.
  4. Apr 9, 2024 at 2:41 PM
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    I always do it cold as the area around the plugs get real hot after driving. Save myself from a burn.
    3JOH22A likes this.
  5. Apr 9, 2024 at 2:41 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The transmission doesn't care. However, access to the fill plug is right by the exhaust pipe and catalytic converter, so it's best to wait until it's cooled down.
    pp2small likes this.
  6. Apr 9, 2024 at 3:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You've got a better chance burning your hand from the hot exhaust pipe than damaging threads in the transmission case.
    TnShooter likes this.
  7. Apr 9, 2024 at 5:53 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    ^^^^This^^^^
    I'll go further: "Over-Night cold". Aluminum cools faster than the iron/steel the plug is made of and will shrink around the plug and effectively lock it in place until the temperatures equalize.
    I stripped the threads in a Volvo head one time removing a spark plug on a warm engine. It felt no different removing it than all the other times I changed the plug on that engine over it's 300,000+ mile life. As soon as I tried installing the new plug and it wouldn't go, I knew something was wrong.
    Helicoil fixed it, and I never did the plugs on anything again unless the engine was fully cold even if it had cast-iron head. I had the plugs done on my Tacoma by a local shop that agreed to drive it into the bay the night before and do the work on a fully cold engine first thing in the morning. I explained why and he immediately agreed. I dropped it off the night before.)
  8. Apr 9, 2024 at 6:11 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The automatic transmission pan is iron. Easily checked with a magnet.
  9. Apr 9, 2024 at 6:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It doesn’t matter.
    I prefer cool, because who likes hot fluid running down their arm?
    The important part is is getting the fluid level correct. :thumbsup:
    Williston and koditten like this.
  10. Apr 9, 2024 at 7:35 PM
    tomrad
    It was the fill plug I was concerned with, not the pan. But I removed it just fine after it was cool.
    Thanks to all for the replies, got the fluid refreshed, and the old stuff didn't look too bad. I did one drain and fill two years ago. I believe this truck had regular fluid changes before I got it. 325k miles and it shifts well, only a very infrequent shudder but only in overdrive.
    koditten, 3JOH22A and Williston like this.
