Removed and replaced cylinder head now truck won't start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skingolo, Nov 25, 2022.
  1. Nov 25, 2022 at 2:44 PM
    Skingolo
    Skingolo [OP] Active Member
    2002 Tacoma 2wd
    So one of my spark plugs stripped out I had to remove the cylinder head to avoid getting metal shavings inside the cylinder got the helicoil in and got it torqued to spec everything seemed fine. I reassembled the motor following alldata procedures to a t. Got everything put back together and the truck started 3 or 4 times would idle really rough and shut itself off after those 4 times now I have no ignition I have no idea what I did wrong and really need my daily back.
  2. Nov 25, 2022 at 2:52 PM
    Skingolo
    2002 Tacoma 2wd
    Working on a 2rz fe out of a 2002 5 speed Tacoma
  3. Nov 25, 2022 at 2:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is there a check engine light on?
    If so, the codes may help point you in the right direction.
    My first suspicion is timing, or a sensor is unplugged.
    wilcam47 and Bivouac like this.
  4. Nov 25, 2022 at 3:03 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Definitely like a sensor for this; easy enough to miss getting one fully seated, but a bit odd that it started a few times and now won't start at all. What do you mean by, 'no ignition'?
    TnShooter likes this.
  5. Nov 25, 2022 at 3:03 PM
    Skingolo
    2002 Tacoma 2wd
    I'm fairly certain timing is good I lined up the dots on the cams and got the timing gear set correctly. And put the cam guides in with proper torque procedure. I've triple checked all the plugs and wires there isn't any that aren't connected. The truck does have a check engine light but I do not have a code reader. Which shall probably be my next step.
  6. Nov 25, 2022 at 3:05 PM
    Skingolo
    2002 Tacoma 2wd
    The truck turned over and ran rough I assumed because it had to relearn the air map. Now the truck is turning over but I have no spark. I sprayed starting fluid into the intake and the truck just kept turning over.
  7. Nov 25, 2022 at 3:12 PM
    TnShooter
    Deogee
    STOCK
    I’d pull the codes. That would help a lot.
  8. Nov 25, 2022 at 3:16 PM
    Skingolo
    2002 Tacoma 2wd
    that definitely seems to be the next step
  9. Nov 25, 2022 at 3:21 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mine idled like normal on the first start, shouldn’t be rough at all.
    How is the maf? Intake tract complete between maf and throttle body?
    Bivouac likes this.
  10. Nov 25, 2022 at 3:27 PM
    Skingolo
    2002 Tacoma 2wd
    Maf is plugged in don't know if it's actualy working or not because I haven't tested it but the intake tubing is assembled, clean, and clamped together as it should be
  11. Nov 28, 2022 at 5:51 PM
    Skingolo
    2002 Tacoma 2wd
    So I read the codes and all 4 of my coil packs aren't getting signal. I've checked all the fuses inside the engine bay and the cab and they're all showing resistance. How exactly do I test the coils themselves before I buy 4 new ones
  12. Nov 28, 2022 at 5:53 PM
    0xDEADBEEF
    If they're not getting signal, they're not going to fire. Look upstream of the coils - the computer isn't firing them because it isn't happy about something, cam sensor perhaps?
  13. Nov 28, 2022 at 5:53 PM
    Bishop84
    Bishop84 Well-Known Member
    4 coils don't fail, something is wrong with what you've done. You need to check the cam and crank sensors to see if they are installed and connected, and remove them to see if tone rings are in place.
    wilcam47, TnShooter and 0xDEADBEEF like this.
  14. Nov 28, 2022 at 5:59 PM
    Skingolo
    2002 Tacoma 2wd
    A piece of plastic on the cam clip broke off but the plug still went in Im assuming that's what it is
    wilcam47 likes this.
  15. Nov 29, 2022 at 7:22 AM
    Skingolo
    2002 Tacoma 2wd
    Replaced camshaft position sensor truck started idled terrible for about 6 seconds then shut off and won't start
    Pulled the codes again and all I'm getting is p0115 which is coolant which makes sense because I haven't put coolant in the truck yet but would that cause the truck to not start
  16. Nov 29, 2022 at 7:31 AM
    Skingolo
    2002 Tacoma 2wd
    I take that back it's still pulling all 4 coil pack codes
  17. Nov 29, 2022 at 7:41 AM
    Skingolo
    2002 Tacoma 2wd
    And now the head of the bolt for the cam sensor snapped off
  18. Nov 29, 2022 at 8:34 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    You have a 4 cylinder or 6 cylinder engine? Why did you remove the head to helicoil? I have the 3.4 and recently found out I had a helicoil already in my #3 cylinder. I bought the Sav-a-thread kit that helicoil makes. Took old one out and put new one in. Works fine and didn't have to remove the head. If I would remove the head I would of just replaced the whole head. The 3.4 only has 3 coil packs. Sounds like you will have to take it back apart and follow all of your steps.
  19. Nov 30, 2022 at 6:10 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I also fixed a stripped spark plug thread without removing head. Oil on the tap will hold the shavings. But that doesn't help you now. But on the positive side, once you figure this out you should be pretty proficient at swapping heads from now on.
    Area51Runner likes this.
  20. Dec 1, 2022 at 2:27 PM
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    From the mention of "all four coil packs", I would deduce that he has a four-banger.
