Removed spacer lift, removed vibes!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeyTacoma, Feb 21, 2011.
  1. Feb 21, 2011 at 1:29 PM
    JoeyTacoma
    JoeyTacoma [OP] Well-Known Member
    Eagle, Colorado
    2017 TRD Off-Road Pro Cement
    285/75 R16 BF Goodrich All Terrain KO2
    After taking out the 2.25 leveling kit in my truck the vibration from the diff. when in two wheel drive also went away! Are they going to come back when I put Billy 5100 in?
  2. Feb 21, 2011 at 1:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Probably - assuming you set the 5100s to the same height.
  3. Feb 21, 2011 at 1:40 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Most likely.
  4. Feb 21, 2011 at 1:42 PM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
    Sounds like the bearing are going out in the front diff. Check the fluid and see if there are any metal shavings on the plug.
  5. Feb 21, 2011 at 2:57 PM
    JoeyTacoma
    Eagle, Colorado
    Does not sound like a bearing to me? why would it be vibrate with 2.5 lift and be gone with no lift. If it was a bearing why did it go away?
  6. Feb 21, 2011 at 4:36 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Tacoma uses center axledisconnect not hubs, so the front axles are always turning, even in 2wd.
    Lifted, the cvs are turning at a greater than stock angle.
  7. Feb 21, 2011 at 4:57 PM
    JoeyTacoma
    Eagle, Colorado
    Good to know. Thanks
