removed wrong drain plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bayrider, Jul 19, 2012.
  1. Jul 19, 2012 at 8:19 PM
    Bayrider
    Bayrider [OP] Active Member
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    I won't go into the how I did it but I unscrewed the drain plug in the tranny of my 2012 v 6 tacoma. I probably lost up to a pint of fluid before I put it back in. Can I drive it 8 miles to a garage to have a real mechanic replace the fluid without damaging the transmission. I live 2 1/2 hours from the nearest Toyota dealer, hence my stupid move. I was on my back without jacking up the truck, reaching blindly for the oil drain. There, I said it. I probably only lost a cup of fluid
  2. Jul 19, 2012 at 8:20 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    why not just take a different vehicle to a local shop and buy a quart of fluid.
  3. Jul 19, 2012 at 8:24 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    You're not the first to have done that
  4. Jul 19, 2012 at 8:24 PM
    blackpearl11
    blackpearl11 Well-Known Member
    2010 tacoma
    Ya, I would just take a different ride, heck you could probably bike it
  5. Jul 19, 2012 at 8:25 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Tow it to a shop that specialist's with a sealed transmisions. From what I read on here you need a special pump for the fluid.
  6. Jul 19, 2012 at 8:25 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I think it has to be Toyota ATF.
    Make the two hour drive and pick up the OEM fluid, top off the tranny and your good to go.
  7. Jul 19, 2012 at 8:33 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If you're only down a pint, I wouldn't be afraid to drive it.
    Somewhere on here there is a thread on how to refill it properly if you want to do it yourself. There are factory service manuals online at TTORA also.
    I would crack open the owner's manual and see what it says for fluid. Chances are good that the local autoparts stores have something that is an equivalent to the factory stuff. These transmissions have been out for awhile now.
  8. Jul 19, 2012 at 8:50 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    Right? :cheers:
  9. Jul 19, 2012 at 9:22 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    ^^^^^ Agree completely, I don't see a litre of fluid loss being an issue to slowly drive yourself to a parts store to fill up, I've seen engines run on 1.5 litres of lost fluid, and since they weren't abused in transit the engine held fine.
    At the end of the day, it's your call.
  10. Jul 19, 2012 at 9:24 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
  11. Jul 19, 2012 at 9:27 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Who let you out of the kitchen?
  12. Jul 19, 2012 at 9:31 PM
    Bennett707
    Oregon
  13. Jul 19, 2012 at 9:43 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    :rofl: The mention of your name and you come running, you must have a search program that looks for new posts witht the word "Krazie" .
  14. Jul 19, 2012 at 10:30 PM
    babytruck
    NorCal
    There's no way in hell I was gonna bring you a sammich so shaddup.
  15. Jul 19, 2012 at 10:32 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
  16. Jul 19, 2012 at 10:33 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^^this...from what I've heard since the auto transmissions are sealed, you need someone with a specialized pump to refill the transmission back up
  17. Jul 20, 2012 at 6:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You guys are incredibly misinformed and should stop spreading the BS. Anyone with basic mechanical skills and tools can refill the transmission. I can assure you, there is no 'special pump' required.
    ^^This. It's not difficult. The fill plug is on the passenger side, slightly further back from the drain plug. Put back the same amount you took out and you're good to go.
  18. Jul 20, 2012 at 6:09 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Special pump. [​IMG]
  19. Jul 20, 2012 at 6:34 AM
    BamaToy1997
    Bill
    Navarre, FL
    Completely correct sir. No special pump needed. Just make sure you use the correct fluid. Don't even THINK of putting in the wrong fluid, because I have seen trucks get STUPID with just a couple quarts of the wrong fluid in it. Strange but true.
  20. Jul 20, 2012 at 6:38 AM
    Pugga
    Massachusetts
    I'm sorry, what? I was busy looking at your sig :eek:
