Removing 1GRFE with 4" lifted truck
Discussion in 'Technical Chat' started by Mach375, Dec 14, 2013.
  1. Dec 16, 2013 at 5:35 AM
    Mach375
    Mach375 [OP] Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Well, I haven't actually tried to pull it yet, but I'm trying to cover all my bases for when I have the picker. I just figured that with the crossbar in front and the ARB bumper, it wouldn't clear. That would be gravy if it did without having to drop the front!
    Say, THAT helps a whole lot!! I may replicate it.
    I also found this with some searching:
    Rather than *buying* temporary hooks from the stealership, I might just try directly bolting some 5/16" transportation chain to the lifting holes, or exhaust bolts, and bolt or hook that with the lift. Or I might just torch-cut some 3/16" plate into hooks.
  2. Dec 16, 2013 at 8:00 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    those two hooks are the ones i got.
  3. Dec 17, 2013 at 11:12 PM
    Mach375
    Engine is out. Had to take off the wheels and 255 tires and set the truck on the brake rotors, but didn't have to compress the suspension. Cleared the radiator by about an inch.
    The real bitch was getting the oil pan to clear the passenger side motor mount, and convincing the transmission it wasn't invited. Otherwise pretty smooth. Glad I took off the exhaust headers!
    Out of curiosity, how much was the dealership engine hook? I spent about $7 in off-the-shelf parts from Homey Despot.
    deanosaurus likes this.
  4. Dec 18, 2013 at 12:29 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Pics of the teardown!
    Also, what is the plan from here? Assess damage, replace broken parts as needed or just full engine swap?
  5. Dec 18, 2013 at 3:36 AM
    Mach375
    I'll try to snap some pics (haven't yet). You're always welcome to swing by if you like and check things out for yourself. Bring a pressure washer or steam cleaner with you :D
    Looking to do a full swap. Word has it there's a motor in HB with my name on it. A factory-sealed motor is going to be superior to anything I put back together.
  6. Mar 18, 2021 at 8:33 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I bought those hooks last year. They were around $40-$50 each for two hooks from TRDshop.
  7. Mar 18, 2021 at 8:43 PM
    Mach375
    Holy thread revival!! This has got to be some kind of record!
    I had almost forgotten I swapped engines. I just got done doing my rack & pinion for the third time (fuck Napa parts. Three racks in three years ain't my idea of fun time)
