Removing 2021 Sr5 dome light cover?
Discussion in 'Technical Chat' started by Perchmeister30000, Dec 28, 2020.
  1. Dec 28, 2020 at 2:08 PM
    Perchmeister30000
    Perchmeister30000 [OP] Member
    Tacoma SR5
    Got all my interior lights switched over to LED, but I cant seem to pry the dome cover off-- I'm using a curved plastic tool, but can't seem to get it-- i can pry what looks like the whole assembly instead of just the cover but it's hard to tell-- i've seen people do it with a forked plastic tool, not sure if i need that-any tips for this light?
    davidstacoma likes this.
  2. Dec 28, 2020 at 4:16 PM
    Mastertoytec
    Mastertoytec Member
    02 taco
    You have to take the whole assembly down. Held in by 4 clips. I push the headliner up with my fingers and give it a good yank. Start with the rear(furthest from the windshield). You have to pull hard
    Perchmeister30000[OP] likes this.
  3. Dec 28, 2020 at 4:26 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    It’s probably the same as my 2019, to remove the dome lens look at the long side facing the front of the truck, you can see two small indents, place your small plastic tool at one of them between the housing edge and the lens and pop it down, repeat for the other indent and slide the lens right out toward you. I used a flat straight plastic trim tool but even a small flat blade screwdriver would work. Easy.
