Removing a lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ControlledChaos, Mar 7, 2024.
  1. Mar 7, 2024 at 9:42 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    How do you adjust the rear axle? I've done many lifts and never found any cam bolts or adjusters to change thrust angle or anything.
  2. Mar 7, 2024 at 9:46 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    That’s why my mechanic did my lift, I don’t have enough knowledge or skill. But when it was done it tracked beautifully at 80 mph
  3. Mar 7, 2024 at 9:46 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Because people all the time manage to remove the nut on the top of the coilover instead of the three bolts that hold it in place. Remove that thing and your day could be bad really fast. That warning is in all the coilover replacement instructions I've read.
    TS4x4 likes this.
  4. Mar 7, 2024 at 9:47 AM
    airforceb2cc
    Don
    KCMO
    I'm almost positive you can't adjust alignment on the rear.
    chasecmc, jmneill, Chew and 2 others like this.
  5. Mar 7, 2024 at 9:48 AM
    YF_Ryan
    Kent, WA
    It's not just a leveling kit. that spacer is maxing out your suspension, I'm betting. You gotta remember a spacer will add like double it's thickness in lift. It might even be more, I can't recall the correct calculation, but it's definitely more than the thickness of the spacer.
    Chew likes this.
  6. Mar 7, 2024 at 9:51 AM
    YF_Ryan
    Kent, WA
    I just did some quick googling, and it sounds like you just need to make sure your bushings and stuff are in good shape, or they could let it out of spec.
    it'd be different if we had track bars and coil springs, or a panhard bar keeping things centered.
  7. Mar 7, 2024 at 9:52 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Hey if you’re comfortable :thumbsup:
  8. Mar 7, 2024 at 10:16 AM
    airforceb2cc
    Don
    KCMO
    Oh I'm comfortable...just not a fan of suggesting a service to someone if it isn't possible. If someone told a shop they wanted all 4 corners aligned and the shop charged $135 per axle and there is no way to align the rear, then they got taken advantage of. So the point of my question was to verify that 1-it isn't possible to align the rear axle and 2-if it is, spread the knowledge to others.
    chasecmc likes this.
  9. Mar 7, 2024 at 10:40 AM
    545
    545 Well-Known Member
    2015 Access Cab
    I quoted and deleted what I said a few times, it all came out as dicky
    There is no adjustment of alignment in the rear for a Tacoma. I suppose that might change with the gen4 coil spring rear end models, but doesn’t change the fact that a 4 wheel alignment is not possible on the OPs vehicle.
    chasecmc, jgr81 and YF_Ryan like this.
  10. Mar 7, 2024 at 10:41 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    So a guy comes on TW asking for information/suggestions, and I give mine. Sorry
    TS4x4 likes this.
  11. Mar 7, 2024 at 10:43 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Just curious, there’s no way to get the rear axle out of square/90* to the frame.?
  12. Mar 7, 2024 at 10:50 AM
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    There is a bolt head/pin on the bottom of the leaf pack that drops into a hole on the spring perch of the axle to hold the leafs in place... that basically serves as the alignment of rear axle. Not much adjustment there, but when you tighten up the ubolts there can be a tiny difference in adjustment fore/aft but not enough to affect anything. If the bolt head in the center of the leaf pack that sits in the perch was sheared off somehow, then that could cause some issues with misalignment of the axle if the ubolts were loose enough to allow any movement
  13. Mar 7, 2024 at 11:03 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Seems reasonable enough.. ¯\_(ツ)_/¯
  14. Mar 7, 2024 at 11:07 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    If I’m not mistaken all alignments are four wheel alignments in that they use the front and rear measurements together. However there is no adjustment for the rear. Pretty sure the only way to change the rear is to replace parts. And since metal has memory it might involve replacing everything or it would likely want to go back where it was.
    I’ll defer to @Bishop84 for more on this.
    jwctaco and YF_Ryan like this.
  15. Mar 7, 2024 at 11:07 AM
    #35
    YF_Ryan
    Kent, WA
    The easiest way to get out of square would be actual damage, in that case parts would need replaced. There is nothing to adjust, only fix.
    jwctaco[QUOTED] likes this.
  16. Mar 7, 2024 at 11:13 AM
    #36
    jmneill
    SE
    I'm gonna peck my way over to the closest aeronautical engineering forum and see if I can help out any of the noobs..
    brb... :thumbsup:
    chasecmc and YF_Ryan like this.
  17. Mar 7, 2024 at 11:17 AM
    #37
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If you look closely, there is one spacer above the coilover between the tophat and chassis, and another one between the spring and the tophat that is adding preload to the spring. Both should be removed to go back to stock. If I was going to leave one, I'd remove the preload spacer. That spring is going to be a pain to compress down.
    jmneill likes this.
  18. Mar 7, 2024 at 11:17 AM
    #38
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    So was my original post wrong-out of line, be glad to delete anything that anyone doesn’t like.
  19. Mar 7, 2024 at 11:43 AM
    #39
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    theres no rear adjustment on these. Mounting position of the axle is fixed.
  20. Mar 7, 2024 at 11:43 AM
    #40
    airforceb2cc
    Don
    KCMO
    Yes, you are correct! There is a preload spacer and a 1/4" spacer above the top hat. Good eye!
    YF_Ryan likes this.
