Removing A Stock Roof Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kioti1, Mar 13, 2021.
  1. Mar 13, 2021 at 9:32 AM
    Kioti1
    Kioti1 [OP] Active Member
    Morning guys. New to the group. I searched the forums but did not find an answer to my question. I haven't purchased my new project yet and that is part of my question. I am looking for a specific truck and I have found what I am looking for but it has the stock Toyota Tacoma roof rack runners on it. Has anyone removed these with success. I guess success would be with no leaks.
    The Tacoma that I am looking for is the 4 door, 4WD with a 6 foot bed. Not the easiest to find and if I could purchase this one and remove the runners with no issues it would be great.
    Thanks in advance
  2. Mar 13, 2021 at 9:40 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    You can seal the holes but when I removed my oem rack the plastic pieces to hold the weather strip were broken and I had to glue the weather strip in. Not to mention it had damaged the paint on the roof and body above the doors
  3. Mar 13, 2021 at 9:44 AM
    Kioti1
    Im not as concern about the paint as I am a leak. Im going to repaint or vinyl wrap anyway. I have a full Yakima system I want to install and it won't work with that stock rack. If I can seal the holes successfully then it will work for me.
  4. Mar 13, 2021 at 11:20 AM
    Oreo Cat
    Just put flex shot in the holes
