removing ABS? prebent brake lines?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sgill1129, Nov 28, 2010.
  1. Nov 28, 2010 at 5:55 PM
    sgill1129
    sgill1129 [OP] New Member
    1990 toyota pick up sr5
    i am a new member with a 1990 toyota pick up, i have a leak in one of my brake lines and i"d liek to know if pre bent lines are available i found one site, however i only need one brake line this site only sells all of brake lines, i was also wondering if removing ABS is an option and the steps/ parts that would be needed to do so
  2. Nov 28, 2010 at 6:03 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    welcome to TW.check with a local dealer on the line.
