Removing ABS sensors
Discussion in 'Technical Chat' started by AKADriver, May 29, 2014.
  1. May 29, 2014 at 7:27 PM
    AKADriver
    AKADriver [OP] Active Member
    NoVA
    03 base 2WD
    I saw a few threads where people asked about this but no solutions given - usually they'd discover that their ABS problem was actually a wiring harness and give up.
    I'm parting out a rear axle and the ABS sensors won't budge. I've popped one out of a clean low-mileage axle and it took a bit of force to loosen the seal. These seem almost fused in place. Is there a trick? Trying to pry them out with a flat-blade screwdriver did nothing. Penetrating oil has been no help.
    I'd like to save the sensors if possible, since these are $150+ parts.
    Should I be able to rotate the sensor in the hole?
