Removing automatic transmission pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fla_sun, Oct 25, 2015.
  1. Feb 27, 2020 at 10:39 AM
    ENGINE326
    ENGINE326 New Member
    Long Island, NY
    2012 DC LB Sport
    Went pretty easy...
    Draining the pan was taking a very long time, so I ended up making a few extra holes in the older/damaged pan to speed up the process.
    if I remember correctly, I didn’t spill much at all. Just residual drips.
    Once the pan was drained, I removed the surrounding bolts, removed the pan, changed the gasket, and replaced the pan with a new one.
    I used the “jumper” method for seeing when the transmission was at temperature. Then I opened one of the plugs (forget what it’s called) until the fluid drained to a trickle.
    If you can give me some time I have the procedure still. I’ll post it.
    Srdjan_c likes this.
  2. Feb 27, 2020 at 10:53 AM
    Srdjan_c
    Srdjan_c New Member
    Srdjan
    2016 Toyota Tacoma TRD sport
    That’s good to hear. And yes if you could post that procedure it would be great, thank you!
  3. Sep 19, 2020 at 8:38 AM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    Sorry to bump an old thread.
    I plan on dropping the pan on my Tacoma in the next couple weeks to replace the metal filter & flush the ATF. Do the transmission pan bolts have Loctite on them?
  4. Sep 19, 2020 at 8:47 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    If you have a Scangauge and monitor the T1 and T2 temps, can you use the readings from it when doing the fluid change procedure?
  5. Sep 19, 2020 at 12:41 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Use a putty knife all around the pan while slightly tapping with a small hammer,and off it comes.
