Removing B pillar vinyl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nimbostratus, Jan 13, 2019.
  1. Jan 13, 2019 at 10:06 PM
    Nimbostratus
    Nimbostratus [OP] Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    Guys who have removed the B pillar vinyl did you use Goo Gone to remove the residue after you got the vinyl off? How did you get the residue from under the window trim? Will getting goo gone under the window trim make it release from the window? Just trying to get an idea of how to do it right without messing up the window trim that I already hear can leak.
  2. Jan 13, 2019 at 11:06 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I used plain alcohol
  3. Jan 13, 2019 at 11:07 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I used WD40 on the residue. Seemed to work really well. Most of the residue came off with the vinyl. If you go slow, and apply just the right amount of heat, almost nothing is left behind. I had a couple little bits I had to pic away at with a plastic putty knife, but nothing that difficult. It was all gone off my truck in under an hour, residue and all.
  4. Jan 13, 2019 at 11:34 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I did mine in the parking garage while on break at work. Took a few minutes to get started and then came off nice and clean.
    Had two or three tiny bits left but goo gone and then a cleaner and wax made it perfect.
  5. Jan 13, 2019 at 11:40 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I am planning on doing the same. I have had several motorcycles in the past. They each had several "don't sue us" stickers on them that were very peal resistant. I left the motorcycle out in the hot summer sun, then a few hours latter I simply pealed the stickers right off. No residue to speak of.
  6. Jan 14, 2019 at 1:02 AM
    Tuna tacos
    Tuna tacos Well-Known Member
    2018 Barcelona SR Double cab 4x4
    Did mine goo gone and wax as well super easy 15-20 minutes
  7. Jan 14, 2019 at 2:38 PM
    Nimbostratus
    Tuscaloosa, AL
    Is goo gone something you need to worry about around window trim? I'm not sure if that trim is held on by an adhesive or not.
