Removing badges
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaddyBoomBoom, Jan 5, 2010.
  1. Jan 5, 2010 at 4:01 PM
    PaddyBoomBoom
    PaddyBoomBoom [OP] Member
    Paddy
    Always moving
    Arctic Runner
    I was thinking about removing all decals and badges for a smooth clean look. What do I need and how much of a pain am I getting into?
  2. Jan 5, 2010 at 4:03 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    its not hard at all. you need a blow dryer or heat gun to warm them up, then take some dental floss and use that to go behind the badge and it should pull right off. you will have some adhesive left over so just clean it up with some goo gone and you're good to go. :)
  3. Jan 5, 2010 at 4:09 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    x2 except i used 10lb test power pro fishing line instead of the floss.(little stronger):)
  4. Jan 5, 2010 at 4:12 PM
    steveh_2007
    steveh_2007 Pro Member
    NW Houston, TX
    07 TRD Sport PreRunner
    TRD Baja Suspension, FN Wheels BFD, TRD Cat-back Exhaust, TRD Cold Air Intake, TRD GrillCraft MX Grilles, FX-R 3.0 Bi-Xenon Retrofit with Osram CBI Bulbs, OEM Navigation/Bluetooth/Backup Camera Retrofit, WeatherTech Floorliners, Valentine One, ScanGuage II with custom V1/SGII BlendMount
    and wear gloves...
  5. Jan 5, 2010 at 4:19 PM
    shakao
    shakao Member
    MN
    Speedway blue
    I use 50lb test PP for frog and jig fishing. ahahahhaha
    this is interesting. Maybe I'll try debadging my truck soon. Does it have to be a certain temperature outside to heat up the badges? The high today was 9 degrees, and the low is suppose to be in the negatives.
  6. Jan 5, 2010 at 4:27 PM
    rhodehard09
    tampa, fl
    thats where the heatgun comes into play
  7. Jan 5, 2010 at 4:31 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    i used a heatgun and a small flathead screwdriver wrapped in tape and they come right off. then use an all purpose cleaner or goo gone to get off any left over residue. then cut compound/ polish or claybar.
    ive also used a stripping wheel for side moldings on other vehicles and that saves your fingers
  8. Jan 5, 2010 at 4:33 PM
    J-Bird
    J-Bird Well-Known Member
    SB, Ca
    09 TRD off-road 4x2 DC
    soon
    Just did mine today, well all the badges on the tailgate and the trd stickers. Kept the "tacoma" on the front doors.
    Anyways it looks reeeeally good, imo.:D
  9. Jan 5, 2010 at 4:34 PM
    J-Bird
    SB, Ca
    soon
    X10000000000000000
    my fingers hurt :(
  10. Jan 5, 2010 at 4:35 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    sounds like an easy way to make a dent.
  11. Jan 5, 2010 at 4:53 PM
    JM76
    JM76 Ride On
    Jon
    SC
    06 silver double cab 4x4
    seconday air filter removal, tw sticker afe pro dry s filter , black rims , cb radio with four foot firestik antenna,black nasta nerf bars,5100's in the rear,mp3 player hookup,led overhead light,5100's up front @ 1.75, rear AAL,custom dent package,blacked out rear bumper, blacking out front grille,camo gt seat covers , 6k HIDs, 6k fogs coming, devil horns grille mod,elite offroad aluminum bumper,Canadoshi grille mod.light bar behind the grille with bright lights coming sooner or later
    x2 or a nice scratch.
  12. Jan 5, 2010 at 4:58 PM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    not to hijack....how do you get the stiker off of the side?
  13. Jan 6, 2010 at 11:26 AM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    Nevermind....Search button is your friend.
    Hairdyer and 3M sound good to me.
  14. Jan 6, 2010 at 3:38 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Defroster mod, Bilstein 5100s front, Adjustable Ranchos rear.
