Removing body lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by nickhalla, Mar 30, 2015.
  1. Mar 30, 2015 at 5:34 AM
    nickhalla
    nickhalla [OP] Active Member
    Nick
    Edwards, CO
    2014 SR5 Access Cab
    OME 886 w/SPC uppers, Dakar leafs and Nitrocharger shocks. Slee Rock Sliders 285/75/16 Yokohama Geolandar MT's on Toyota steelies
    I bought my truck with a 3" body lift. I'm wanting to remove it but haven't seen anything on the forum about doing this. Do I have to replace the pucks with bushings or can I just get some shorter bolts and bolt the body back on flush with the frame?
  2. Apr 1, 2015 at 12:02 PM
    drummel1
    drummel1 Asks annoying questions
    Baltimore, MD
    96 SR5
    Big Ass Bumper, frame sliders, CS-114, multimount winch
    Out of curiosity, why are you taking it off?
  3. Apr 1, 2015 at 12:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    ^^^ unsafe, ugly, causes body damage, doesnt give ground clearance but raises centre of gravity, etc...
  4. Apr 1, 2015 at 12:57 PM
    Stephen1231
    Stephen1231 Well-Known Member
    Stephen
    Mobile Al
    95.5 Tacoma 4x4 2.7 5spd
    Engine freshly rebuilt due to blown head gasket, built my own CAI, EGR delete from LCEngineering, Billstein 5125's in the back with GM leafs, I can't stand paying for something that I can make in my garage so I built my own spacers for the front and tweaked them for 3" of lift.
    I bought my truck with a 3'' body lift also and I took it off. I replaced all my body bushings for less than $100, I went with the Energy Suspension kit, I got it from Summit Racing. Keep in mind that you have to replace your cab bolts with shorter ones also.
  5. Apr 2, 2015 at 4:28 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    There is a one inch kit that summit sells, I believe its energy suspension as well and it comes with the necessary bolts, it's a good compromise and gives access for cleaning to the top of the frame.
  6. Apr 2, 2015 at 8:17 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    unsafe if done wrong, does not cause body damage, no ground clearance increase, but doesn't raise the center of gravity as much as a suspension lift does.
    now saying that, i would only do a 1" body lift.
  7. Apr 2, 2015 at 8:33 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Best decision I ever made, go look up roger brown body lifts he also sells the kits to go back to stock I removed my 3"
  8. Apr 2, 2015 at 8:39 PM
    devinzz1
    devin
    2023 aclb trd or mt
    I havent been on the site for very long and already seen a few cases where a 3" puck can flex and wear through or crack where it mounts to body. Some people add an extra plate between puck and body to add some strength. I meant it raises the cog without giving you more ground clearance. I would only use a 1 or 1.5" if i needed the tire clearance.
