Removing bolts in the bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bbottom, Jan 6, 2022.
  1. Jan 7, 2022 at 10:04 AM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    3/8 hand impact driver if they are all that tight. If a torx slips it pretty well trashes the bolt. If you are trying the big bed bolts crawl under it first the some PB blaster then coat it with anti seize when you put it back in.
  2. Jan 7, 2022 at 8:59 PM
    #42
    bbottom
    bbottom [OP] Active Member
    So I picked up an impact screw driver and those bits that pull out stripped screws. The impact screw driver wouldn’t fit. And the bits would have worked….but the bolt is in there so tight that it won’t turn.
    So tomorrow I’m going to picked up a dremmel and try to cut a notch in the bolt head so that the impact driver will fit in it.
    I can’t believe how hard these things are to remove
  3. Jan 7, 2022 at 9:18 PM
    #43
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    I had to take these out a few months ago and remembered it was a PITA. I’m trying to remember what I did to ultimately get them out. I think I hit it with pb blaster and let it soak over night. When and if you do get them out, replace with premium hardware. Ace has a way better selection than Home Depot and lowes from what I’ve seen for metric.
    davidstacoma likes this.
  4. Jan 7, 2022 at 9:24 PM
    #44
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Dremel a straight deep notch and a big ass flat head screw driver is what finally did it for me man. Was a total “FUCK YES” moment when i got them all out
    MIDTNTACO likes this.
  5. Jan 7, 2022 at 9:32 PM
    #45
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I destroyed a few of those and replaced them with m6x1.0 10mm bolt heads.
    bbottom[OP] and davidstacoma like this.
  6. Jan 7, 2022 at 9:47 PM
    #46
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I used an impact wrench set on low to lightly pound them free. They’ll come out but you have to be patient and make sure your torx is strong and fits tight.
  7. Jan 7, 2022 at 10:07 PM
    #47
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Been wanting a hammer impact driver, thanks for the link.
  8. Jan 8, 2022 at 1:19 PM
    #48
    Tacomike18
    J
    If anyone in SoCal wants a free front bed rail, all you have to do is removed the stripped bolt head from my truck.
    AmateurTaco1313 likes this.
  9. Jan 8, 2022 at 3:22 PM
    #49
    AmateurTaco1313
    ROK
    Enough for now
    got a picture of the bolt?
  10. Jan 8, 2022 at 3:32 PM
    #50
    Tacomike18
    J
    Don’t have a pic of it right now but it’s the most left bolt. I completely stripped the star hole.
  11. Jan 8, 2022 at 5:32 PM
    #51
    bbottom
    Well I got the bolts cut. I had to use the impact drill to get them out. There was no way they were coming out by hand. The sports bar is in and I’m ready to take Jennifer to the lake for the weekend!
    Thanks for all of your help
  12. Jan 8, 2022 at 5:43 PM
    #52
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    Sports Bar? Lets see the pics!
  13. Jan 8, 2022 at 9:13 PM
    #53
    bbottom
    I’ll take some in morning.
  14. Jan 9, 2022 at 9:19 AM
    #54
    bbottom
    Boom!
